[petsc-dev] circular dependencies SLEPc
    Patrick Sanan
    patrick.sanan at gmail.com
    Wed Jun 26 13:15:48 CDT 2019
How about a plug-in PC implementation, compiled as its own dynamic library,
depending on both SLEPc and PETSc?
Smith, Barry F. via petsc-dev <petsc-dev at mcs.anl.gov> schrieb am Mi. 26.
Juni 2019 um 21:07:
> > On Jun 26, 2019, at 10:55 AM, Jed Brown <jed at jedbrown.org> wrote:
> > "Smith, Barry F. via petsc-dev" <petsc-dev at mcs.anl.gov> writes:
> >>> On Jun 26, 2019, at 9:56 AM, Balay, Satish via petsc-dev <
> petsc-dev at mcs.anl.gov> wrote:
> >>> On Wed, 26 Jun 2019, Jakub Kruzik via petsc-dev wrote:
> >>>> Hello,
> >>>> as I mentioned in PR #1819, I would like to use SLEPc in PETSc.
> >>>> Currently when PETSc is configured with --download-slepc, it defines
> >>>> PETSC_HAVE_SLEPC and each compilation of PETSc recompiles SLEPc.
> >>> yes - slepc uses petsc, so when petsc is updated - its best to rebuild
> slepc
> >>> You can ignore PETSC_HAVE_SLEPC flag [its just a build tool thingy]
> >>> PETSc code does not use this flag - and there is no circular
> >>> dependency.
> >>>> The first way to use SLEPc is from an example. That should be easy,
> all we
> >>>> need is to add -lslepc when compiling an example.
> >>> Its best to use slepc examples as templates - and slepc makefiles [as
> examples].
> >>> --download-slepc is a convinence feature to install petsc and slepc in
> >>> a single go. It does not change how you would use slepc.
> >>> Satish
> >>>> The other option is to use SLEPc inside PETSc code. I do not know how
> to
> >>>> achieve this. One way could be to define PETSC_HAVE_SLEPC after the
> >>>> compilation of SLEPc and again compile PETSc but this time linking
> with SLEPc.
> >>>> Although, even if it works, it is ugly.
> >>   If you make SLEPc calls from PETSc source you should only need the
> SLEPc header files to compile the PETSc source; not the SLEPc library. So
> one way to accomplish this would be to do a "partial" install of SLEPc,
> build PETSc (that uses SLEPc) and then complete the SLEPc install. When
> --download-slepc is used this would mean during the SLEPc.py script it
> would copy over the SLEPc include files to the prefix location and after
> PETSc is built it would build the SLEPc libraries and move them to the
> prefix location.  The on iffy thing is that SLEPc include files may depend
> on generated PETSc include files (which are not fully generated until
> configure is done). Thus instead of having SLEPc.py move the SLEPc include
> to the prefix location it would need to post-pone that until just at the
> end of configure (we have other packages to do this). So when you ready to
> try this out let us know and we can help with the infrastructure. (it will
> avoid 2 builds of either PETSc or SLEPc).
> > That is disgusting.
> > If code in libpetsc.so depends on libslepc.so, then you'd have a
> circular dependency.
> > You can implement and register a PC in SLEPc (it would go in
> libslepc.so).
>   It makes no sense to have a PC in SLEPc.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190626/ec28c1d4/attachment.html>
