[petsc-dev] circular dependencies SLEPc
Matthew Knepley
knepley at gmail.com
Wed Jun 26 12:01:51 CDT 2019
On Wed, Jun 26, 2019 at 12:45 PM Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> >> You can implement and register a PC in SLEPc (it would go in
> libslepc.so).
> > I think this is the bad workflow solution. What Barry suggested will work
> > and be MUCH easier for a developer. Isn't
> > the point of our tools to make our lives easier, not to enforce rules
> that
> > make them harder?
> Circular dependencies with a special build process is an enormous
> development and distribution tax.
The difference in the arguments here is that there are very specific
problems with the "right" way,
namely that I need to deal with two different repos, two testing systems,
release schedules, etc.
Whereas the taxes above are currently theoretical.
Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190626/0e1a2424/attachment.html>
