[petsc-dev] circular dependencies SLEPc
Jakub Kruzik
jakub.kruzik at vsb.cz
Wed Jun 26 08:03:32 CDT 2019
Hello,
as I mentioned in PR #1819, I would like to use SLEPc in PETSc.
Currently when PETSc is configured with --download-slepc, it defines
PETSC_HAVE_SLEPC and each compilation of PETSc recompiles SLEPc.
The first way to use SLEPc is from an example. That should be easy, all
we need is to add -lslepc when compiling an example.
The other option is to use SLEPc inside PETSc code. I do not know how to
achieve this. One way could be to define PETSC_HAVE_SLEPC after the
compilation of SLEPc and again compile PETSc but this time linking with
SLEPc. Although, even if it works, it is ugly.
Any ideas on how to achieve the second option?
Cheers,
Jakub
