[petsc-dev] PETSc blame digest (next) 2019-06-20
Václav Hapla
vaclav.hapla at erdw.ethz.ch
Thu Jun 20 15:09:09 CDT 2019
Yes, I think that's the reason we moved it to private :-)
Sometimes I see _Internal. I thought _Private is preferred for static functions visible only within a single object file?
Vaclav
20. června 2019 21:50:29 SELČ, "Smith, Barry F." <bsmith at mcs.anl.gov> napsal:
>It HAS A hid_t argument! Making it public means making HDF5 includes
>public, means all PETSc applications have the HDF5 includes open in
>them. Likely it should just get _Private
> Barry
>On Jun 20, 2019, at 9:01 AM, Hapla Vaclav via petsc-dev
><petsc-dev at mcs.anl.gov> wrote:
>> On 20 Jun 2019, at 15:56, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>
>wrote:
>/home/sandbox/petsc/petsc.next-3/src/mat/impls/dense/seq/densehdf5.c:62:
>undefined reference to `PetscViewerHDF5Load'
>>>>>>> Does it mean I need to change visibility of PetscViewerHDF5Load
>in isimpl.h to PETSC_EXTERN?
>>>>>>> Are you OK with that?
>>>>>> Yes, and when doing that, it needs a Developer level man page.
>>>>> OK, thanks.
>>>> So as a rule of thumb, every PETSC_EXTERN function should be
>documented, although in private headers?
>>>> Then src/vec/is/utils/hdf5io.c should have
>>>> #include <petsc/private/isimpl.h> /*I "petsc/private/isimpl.h" I*/
>>>> Looks a bit weird, doesn't it?
>>>> I think there are countless cases petsc-wide which break this.
>>> dev manual page 15 bullet 15:
>>> "private functions may need to be marked PETSC_EXTERN"
>>> There is an example of MatHeaderReplace. It hasn't a manpage.
>> Well, I'm not against making it public (it originally was) and write
>a manpage, but then it should be also moved to the public header file.
>> Sorry for sending a few previous emails only to Jed.
>> Vaclav
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190620/63451b2c/attachment.html>
