[petsc-dev] Controlling matrix type on different levels of multigrid hierarchy? (Motivation is GPUs)
Mills, Richard Tran
rtmills at anl.gov
Wed Jun 12 11:38:49 CDT 2019
Colleagues,
I think we ought to have a way to control which levels of a PETSc multigrid solve happen on the GPU vs. the CPU, as I'd like to keep coarse levels on the CPU, but run the calculations for finer levels on the GPU. Currently, for a code that is using a DM to manage its grid, one can use GPUs inside the application of PCMG by doing putting something like
-dm_mat_type aijcusparse -dm_vec_type cuda
on the command line. What I'd like to be able to do is to also control which levels get plain AIJ matrices and which get a GPU type, maybe via something like
-mg_levels_N_dm_mat_type aijcusparse -mg_levels_N_dm_mat_type cuda
for level N. (Being able to specify a range of levels would be even nicer, but let's start simple.)
Maybe doing the above is as simple as making sure that DMSetFromOptions() gets called for the DM for each level. But I think I may be not understanding some sort of additional complications. Can someone who knows the PCMG framework better chime in? Or do others have ideas for a more elegant way of giving this sort of control to the user?
Best regards,
Richard
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190612/f238b2b3/attachment.html>
