[petsc-dev] better regular testing on accelerators
Jed Brown
jed at jedbrown.org
Wed Jun 12 09:58:25 CDT 2019
Would it be sufficient to add the CUDA arguments to PETSC_OPTIONS when running the test suite on those machines?
"Smith, Barry F. via petsc-dev" <petsc-dev at mcs.anl.gov> writes:
> In order to get better testing on the accelerators I think we need to abandon the -vec_type cuda approach scattered through a handful of examples and instead test ALL examples that are feasible automatically with the various accelerator options. I think essentially any examples that use AIJ are feasible for testing (those that use BAIJ, SBAIJ, Ell are not) I am not sure if there is an automatic way to determine all of these cases. Labeling all such test cases manually would likely miss some and be out of date immediately.
> Any thoughts?
> Thanks
> Barry
> Maybe we could short circuit the issue by having a mode of configuring or compiling or running where MatCreate_AIJ and VecCreate_ are bypassed directly to the accelerator cousins (this is not completely trivial because the cousins generally construct the basic ones and then convert themselves to the cousin).
