[petsc-dev] Unevenly distributed MatNest and FieldSplit
    Pierre Jolivet
    pierre.jolivet at enseeiht.fr
    Wed Jun 12 01:44:25 CDT 2019
Hello,
We are using a SNES to solve a steady-state FSI problem.
The operator is defined as a MatNest with multiple fields.
Some submatrices are entirely defined on a subset of processes (but they are still created on the same communicator as the MatNest).
The preconditioner is defined as a FieldSplit.
During the first call to KSPSolve within SNESSolve, I’m getting this (with debugging turned on):
[0]PETSC ERROR: VecGetSubVector() line 1243 in /Users/jolivet/Documents/repositories/petsc/src/vec/vec/interface/rvector.c MPI_Allreduce() called in different locations (code lines) on different processors
[2]PETSC ERROR: VecNorm_MPI() line 57 in /Users/jolivet/Documents/repositories/petsc/src/vec/vec/impls/mpi/pvec2.c MPI_Allreduce() called in different locations (code lines) on different processors
[1]PETSC ERROR: VecNorm_MPI() line 57 in /Users/jolivet/Documents/repositories/petsc/src/vec/vec/impls/mpi/pvec2.c MPI_Allreduce() called in different locations (code lines) on different processors
As you may have guessed, process 0 (resp. 1–2) is where the structure (resp. fluid) is handled.
I’m attaching both stacks. I don’t see what could trigger such an error from my side, since everything is delegated to PETSc in the SNESSolve.
Is there an easy way to debug this?
Is there some way to dump _everything_ related to a KSP (Mat + PC + ISes) for “easier” debugging?
Thank you,
Pierre
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190612/aae46049/attachment.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190612/aae46049/attachment-0001.txt>
