[petsc-dev] --force goes into reconfigure file
Balay, Satish balay at mcs.anl.gov
Thu Jun 6 11:34:56 CDT 2019
Fixed in
https://bitbucket.org/petsc/petsc/pull-requests/1760/configure-do-not-save-force-option-in/diff
Satish
On Thu, 6 Jun 2019, Smith, Barry F. via petsc-dev wrote:
>   which will also force a another configure even though non is needed
> #!/usr/local/opt/python at 2/bin/python2.7
> if __name__ == '__main__':
>   import sys
>   import os
>   sys.path.insert(0, os.path.abspath('config'))
>   import configure
>   configure_options = [
>     '--force',
>     'PETSC_ARCH=arch-debug',
>   configure.petsc_configure(configure_options)
> ~/Src/petsc (barry/optimize-aij-da *) arch-debug
> $ arch-debug/lib/petsc/conf/reconfigure-arch-debug.py
>              Configuring PETSc to compile on your system
