[petsc-dev] DMDAGlobalToNatural errors with Ubuntu:latest; gcc 7 & Open MPI 2.1.1
Smith, Barry F.
bsmith at mcs.anl.gov
Tue Jul 30 20:39:52 CDT 2019
Note in init.c that, by default, PETSc does not use PetscTrMallocDefault() when valgrind is running; because it doesn't necessarily make sense to put one memory checker on top of another memory checker. So, at a glance, I'm puzzled how it can be in the routine PetscTrMallocDefault(). Do you perhaps have -malloc_debug in a .petscrc file or in the environmental variable PETSC_OPTIONS? Anyways there is a problem but perhaps this is a hint where the problem is coming from?
Barry
> On Jul 30, 2019, at 5:38 PM, Zhang, Junchao via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> Fabian,
> I happen have a Ubuntu virtual machine and I could reproduce the error with your mini-test, even with two processes. It is horrible to see wrong results in such a simple test.
> We'd better figure out whether it is a PETSc bug or an OpenMPI bug. If it is latter, which MPI call is at fault.
> --Junchao Zhang
> On Tue, Jul 30, 2019 at 9:47 AM Fabian.Jakub via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> Dear Petsc Team,
> Our cluster recently switched to Ubuntu 18.04 which has gcc 7.4 and
> (Open MPI) 2.1.1 - with this I ended up with segfault and valgrind
> errors in DMDAGlobalToNatural.
> This is evident in a minimal fortran example such as the attached
> example petsc_ex.F90
> with the following error:
> ==22616== Conditional jump or move depends on uninitialised value(s)
> ==22616== at 0x4FA5CDB: PetscTrMallocDefault (mtr.c:185)
> ==22616== by 0x4FA4DAC: PetscMallocA (mal.c:413)
> ==22616== by 0x5090E94: VecScatterSetUp_SF (vscatsf.c:652)
> ==22616== by 0x50A1104: VecScatterSetUp (vscatfce.c:209)
> ==22616== by 0x509EE3B: VecScatterCreate (vscreate.c:280)
> ==22616== by 0x577B48B: DMDAGlobalToNatural_Create (dagtol.c:108)
> ==22616== by 0x577BB6D: DMDAGlobalToNaturalBegin (dagtol.c:155)
> ==22616== by 0x5798446: VecView_MPI_DA (gr2.c:720)
> ==22616== by 0x51BC7D8: VecView (vector.c:574)
> ==22616== by 0x4F4ECA1: PetscObjectView (destroy.c:90)
> ==22616== by 0x4F4F05E: PetscObjectViewFromOptions (destroy.c:126)
> and consequently wrong results in the natural vec
> I was looking at the fortran example if I did forget something but I can
> also see the same error, i.e. not being valgrind clean, in pure C - PETSc:
> cd $PETSC_DIR/src/dm/examples/tests && make ex14 && mpirun
> --allow-run-as-root -np 2 valgrind ./ex14
> I then tried various docker/podman linux distributions to make sure that
> my setup is clean and to me it seems that this error is confined to the
> particular gcc version 7.4 and (Open MPI) 2.1.1 from the ubuntu:latest repo.
> I tried other images from dockerhub including
> gcc:7.4.0 :: where I could neither install openmpi nor mpich through
> apt, however works with --download-openmpi and --download-mpich
> ubuntu:rolling(19.04) <-- work
> debian:latest & :stable <-- works
> ubuntu:latest(18.04) <-- fails in case of openmpi, but works with mpich
> or with petsc-configure --download-openmpi or --download-mpich
> Is this error with (Open MPI) 2.1.1 a known issue? In the meantime, I
> guess I'll go with a custom mpi install but given that ubuntu:latest is
> widely spread, do you think there is an easy solution to the error?
> I guess you are not eager to delve into this issue with old mpi versions
> but in case you find some spare time, maybe you find the root cause
> and/or a workaround.
> Many thanks,
> Fabian
