[petsc-dev] DMDAGlobalToNatural errors with Ubuntu:latest; gcc 7 & Open MPI 2.1.1
Smith, Barry F.
bsmith at mcs.anl.gov
Tue Jul 30 13:21:28 CDT 2019
Satish,
Can you please add to MPI.py a check for this and simply reject it telling the user there are bugs in that version of OpenMP/ubuntu?
It is not debuggable, and hence not fixable and wastes everyones time and could even lead to wrong results (which is worse than crashing). We've had multiple reports of this.
Barry
> On Jul 30, 2019, at 10:17 AM, Balay, Satish via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> We've seen such behavior with ubuntu default OpenMPI - but have no
> idea why this happens or if we can work around it.
> Last I checked - the same version of openmpi - when installed
> separately did not exhibit such issues..
> Satish
> On Tue, 30 Jul 2019, Fabian.Jakub via petsc-dev wrote:
>> Dear Petsc Team,
>> Our cluster recently switched to Ubuntu 18.04 which has gcc 7.4 and
>> (Open MPI) 2.1.1 - with this I ended up with segfault and valgrind
>> errors in DMDAGlobalToNatural.
>> This is evident in a minimal fortran example such as the attached
>> example petsc_ex.F90
>> with the following error:
>> ==22616== Conditional jump or move depends on uninitialised value(s)
>> ==22616== at 0x4FA5CDB: PetscTrMallocDefault (mtr.c:185)
>> ==22616== by 0x4FA4DAC: PetscMallocA (mal.c:413)
>> ==22616== by 0x5090E94: VecScatterSetUp_SF (vscatsf.c:652)
>> ==22616== by 0x50A1104: VecScatterSetUp (vscatfce.c:209)
>> ==22616== by 0x509EE3B: VecScatterCreate (vscreate.c:280)
>> ==22616== by 0x577B48B: DMDAGlobalToNatural_Create (dagtol.c:108)
>> ==22616== by 0x577BB6D: DMDAGlobalToNaturalBegin (dagtol.c:155)
>> ==22616== by 0x5798446: VecView_MPI_DA (gr2.c:720)
>> ==22616== by 0x51BC7D8: VecView (vector.c:574)
>> ==22616== by 0x4F4ECA1: PetscObjectView (destroy.c:90)
>> ==22616== by 0x4F4F05E: PetscObjectViewFromOptions (destroy.c:126)
>> and consequently wrong results in the natural vec
>> I was looking at the fortran example if I did forget something but I can
>> also see the same error, i.e. not being valgrind clean, in pure C - PETSc:
>> cd $PETSC_DIR/src/dm/examples/tests && make ex14 && mpirun
>> --allow-run-as-root -np 2 valgrind ./ex14
>> I then tried various docker/podman linux distributions to make sure that
>> my setup is clean and to me it seems that this error is confined to the
>> particular gcc version 7.4 and (Open MPI) 2.1.1 from the ubuntu:latest repo.
>> I tried other images from dockerhub including
>> gcc:7.4.0 :: where I could neither install openmpi nor mpich through
>> apt, however works with --download-openmpi and --download-mpich
>> ubuntu:rolling(19.04) <-- work
>> debian:latest & :stable <-- works
>> ubuntu:latest(18.04) <-- fails in case of openmpi, but works with mpich
>> or with petsc-configure --download-openmpi or --download-mpich
>> Is this error with (Open MPI) 2.1.1 a known issue? In the meantime, I
>> guess I'll go with a custom mpi install but given that ubuntu:latest is
>> widely spread, do you think there is an easy solution to the error?
>> I guess you are not eager to delve into this issue with old mpi versions
>> but in case you find some spare time, maybe you find the root cause
>> and/or a workaround.
>> Many thanks,
>> Fabian
