[petsc-dev] MatPinToCPU
Mark Adams
mfadams at lbl.gov
Mon Jul 29 17:26:56 CDT 2019
On Mon, Jul 29, 2019 at 5:31 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> I don't understand the notation in the legend on the second page
> 12,288 cpus and no GPUs ?
Yes
> 24 GPUs? or 6 GPUs
24 virtual, 6 real GPUs per node. The first case is one node, 24 cores/vGPUs
> 192 GPUs?
> 1536 GPUs?
> 12,288 GPUs? or 12288/4 = 3072 GPUs?
All "GPUs" are one core/process/vGPU. So 12288 virtual GPUs and 3072
physical GPUs.
Maybe I should add 'virtual GPUs' and put (4 processes/SUMMIT GPU)
> So on the largest run using GPUs or not takes pretty much exactly the same
> amount of time?
yes. The raw Mat-vec is about 3x faster with ~95K equations/process. I've
attached the data.
> What about 6 GPUs vs 24 CPUs ? Same equal amount of time.
> Can you send some log summaries
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190729/c6eaa479/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190729/c6eaa479/attachment-0005.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190729/c6eaa479/attachment-0006.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190729/c6eaa479/attachment-0007.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190729/c6eaa479/attachment-0008.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190729/c6eaa479/attachment-0009.obj>
