[petsc-dev] MatPinToCPU
Karl Rupp rupp at iue.tuwien.ac.at
Sun Jul 28 13:33:58 CDT 2019
Hi Mark,
feel free to submit a fresh pull request now. I looked at your latest
commit in the repository in order to cherry-pick it, but it looked like
it had a few other bits in it as well.
Best regards,
Karli
On 7/28/19 6:27 PM, Mark Adams via petsc-dev wrote:
> This is looking good. I'm not seeing the numerical problems, but I've
> just hid them by avoiding the GPU on coarse grids.
> Should I submit a pull request now or test more or wait for Karl?
> On Sat, Jul 27, 2019 at 7:37 PM Mark Adams <mfadams at lbl.gov
> <mailto:mfadams at lbl.gov>> wrote:
>     Barry, I fixed CUDA to pin to CPUs correctly for GAMG at least.
>     There are some hacks here that we can work on.
>     I will start testing it tomorrow, but I am pretty sure that I have
>     not regressed. I am hoping that this will fix the numerical
>     problems, which seem to be associated with empty processors.
>     I did need to touch code outside of GAMG and CUDA. It might be nice
>     to test this in a next.
>     GAMG now puts all reduced processorg grids on the CPU. This could be
>     looked at in the future.
>     On Sat, Jul 27, 2019 at 1:00 PM Smith, Barry F. <bsmith at mcs.anl.gov
>     <mailto:bsmith at mcs.anl.gov>> wrote:
>          > On Jul 27, 2019, at 11:53 AM, Mark Adams <mfadams at lbl.gov
>          > On Sat, Jul 27, 2019 at 11:39 AM Smith, Barry F.
>         <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>> wrote:
>          >   Good catch. Thanks. Maybe the SeqCUDA has the same problem?
>          > THis is done  (I may have done it).
>          > Now it seems to me that when you call VecPinToCPU you are
>         setting up and don't have data, so this copy does not seem
>         necessary. Maybe remove the copy here:
>          > PetscErrorCode VecPinToCPU_MPICUDA(Vec V,PetscBool pin)
>          >   PetscErrorCode ierr;
>          >   PetscFunctionBegin;
>          >   V->pinnedtocpu = pin;
>          >   if (pin) {
>          >     ierr = VecCUDACopyFromGPU(V);CHKERRQ(ierr); ????
>             The copy from GPU should actually only do anything if the
>         GPU already has data and PETSC_OFFLOAD_GPU. If the GPU does not
>         have data
>         the copy doesn't do anything. When one calls VecPinToCPU() one
>         doesn't know where the data is so the call must be made, but it
>         may do nothing
>            Note that VecCUDACopyFromGPU() calls
>         VecCUDAAllocateCheckHost() not VecCUDAAllocateCheck() so the GPU
>         will not allocate space,
>         VecCUDAAllocateCheck() is called from VecCUDACopyToGPU().
>             Yes, perhaps the naming could be more consistent:
>         1) in one place it is Host in an other place it is nothing
>         2) some places it is Host, Device, some places GPU,CPU
>             Perhaps Karl can make these all consistent and simpler in
>         his refactorization
>            Barry
>          > or
>          > Not allocate the GPU if it is pinned by added in a check here:
>          > PetscErrorCode VecCUDAAllocateCheck(Vec v)
>          >   cudaError_t    err;
>          >   cudaStream_t   stream;
>          >   Vec_CUDA       *veccuda;
>          >   PetscFunctionBegin;
>          >   if (!v->spptr) {
>          >     ierr = PetscMalloc(sizeof(Vec_CUDA),&v->spptr);CHKERRQ(ierr);
>          >     veccuda = (Vec_CUDA*)v->spptr;
>          > if (v->valid_GPU_array != PETSC_OFFLOAD_CPU) {
>          >     err =
>         cudaMalloc((void**)&veccuda->GPUarray_allocated,sizeof(PetscScalar)*((PetscBLASInt)v->map->n));CHKERRCUDA(err);
>          >     veccuda->GPUarray = veccuda->GPUarray_allocated;
>          >     err = cudaStreamCreate(&stream);CHKERRCUDA(err);
>          >     veccuda->stream = stream;
>          >     veccuda->hostDataRegisteredAsPageLocked = PETSC_FALSE;
>          >     if (v->valid_GPU_array == PETSC_OFFLOAD_UNALLOCATED) {
>          >       if (v->data && ((Vec_Seq*)v->data)->array) {
>          >         v->valid_GPU_array = PETSC_OFFLOAD_CPU;
>          >       } else {
>          >         v->valid_GPU_array = PETSC_OFFLOAD_GPU;
>          >   PetscFunctionReturn(0);
>          > > On Jul 27, 2019, at 10:40 AM, Mark Adams <mfadams at lbl.gov
>          > > Yea, I just figured out the problem. VecDuplicate_MPICUDA
>         did not call PinToCPU or even copy pinnedtocpu. It just copied
>         ops, so I added and am testing:
>          > >   ierr =
>         VecCreate_MPICUDA_Private(*v,PETSC_TRUE,w->nghost,0);CHKERRQ(ierr);
>          > >   vw   = (Vec_MPI*)(*v)->data;
>          > >   ierr = PetscMemcpy((*v)->ops,win->ops,sizeof(struct
>         _VecOps));CHKERRQ(ierr);
>          > >   ierr = VecPinToCPU(*v,win->pinnedtocpu);CHKERRQ(ierr);
>          > > Thanks,
>          > > On Sat, Jul 27, 2019 at 11:33 AM Smith, Barry F.
>          > >   I don't understand the context. Once a vector is pinned
>         to the CPU the flag should be PETSC_OFFLOAD_CPU permanently
>         until the pin to cpu is turned off.  Do you have a pinned vector
>         that has the value PETSC_OFFLOAD_GPU?  For example here it is
>         set to PETSC_OFFLOAD_CPU
>          > >   if (pin) {
>          > >     V->valid_GPU_array = PETSC_OFFLOAD_CPU; /* since the
>         CPU code will likely change values in the vector */
>          > >   Is there any way to reproduce the problem?
>          > >   Barry
>          > > > On Jul 27, 2019, at 10:28 AM, Mark Adams <mfadams at lbl.gov
>          > > > I'm not sure what to do here. The problem is that
>         pinned-to-cpu vectors are calling VecCUDACopyFromGPU here.
>          > > > Should I set x->valid_GPU_array to something else, like
>         PETSC_OFFLOAD_CPU, in PinToCPU so this block of code i s not
>         executed?
>          > > > PetscErrorCode VecGetArray(Vec x,PetscScalar **a)
>          > > > #if defined(PETSC_HAVE_VIENNACL)
>          > > >   PetscBool      is_viennacltype = PETSC_FALSE;
>          > > > #endif
>          > > >   PetscFunctionBegin;
>          > > >   PetscValidHeaderSpecific(x,VEC_CLASSID,1);
>          > > >   ierr = VecSetErrorIfLocked(x,1);CHKERRQ(ierr);
>          > > >   if (x->petscnative) {
>          > > > #if defined(PETSC_HAVE_VIENNACL) || defined(PETSC_HAVE_CUDA)
>          > > >     if (x->valid_GPU_array == PETSC_OFFLOAD_GPU) {
>          > > >       ierr =
>         PetscObjectTypeCompareAny((PetscObject)x,&is_viennacltype,VECSEQVIENNACL,VECMPIVIENNACL,VECVIENNACL,"");CHKERRQ(ierr);
>          > > >       if (is_viennacltype) {
>          > > >         ierr = VecViennaCLCopyFromGPU(x);CHKERRQ(ierr);
>          > > >       } else
>          > > > #endif
>          > > > #if defined(PETSC_HAVE_CUDA)
>          > > >         ierr = VecCUDACopyFromGPU(x);CHKERRQ(ierr);
>          > > > #endif
>          > > >     } else if (x->valid_GPU_array ==
>          > > >       ierr =
>          > > >         ierr = VecViennaCLAllocateCheckHost(x);CHKERRQ(ierr);
>          > > >       } else
>          > > > #endif
>          > > >         ierr = VecCUDAAllocateCheckHost(x);CHKERRQ(ierr);
>          > > > #endif
>          > > > #endif
>          > > >     *a = *((PetscScalar**)x->data);
>          > > >   } else {
>          > > > On Tue, Jul 23, 2019 at 9:18 PM Smith, Barry F.
>          > > >  Yes, it needs to be able to switch back and forth
>         between the CPU and GPU methods so you need to move into it the
>         setting of the methods that is currently directly in the create
>         method. See how  MatConvert_SeqAIJ_SeqAIJViennaCL() calls ierr =
>         MatPinToCPU_SeqAIJViennaCL(A,PETSC_FALSE);CHKERRQ(ierr); to set
>         the methods for the GPU initially.
>          > > >   Barry
>          > > > > On Jul 23, 2019, at 7:32 PM, Mark Adams
>         <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>          > > > >   What are the symptoms of it not working? Does it
>         appear to be still copying the matrices to the GPU? then running
>         the functions on the GPU?
>          > > > > The object is dispatching the CUDA mat-vec etc.
>          > > > >   I suspect the pinning is incompletely done for CUDA
>         (and MPIOpenCL) matrices.
>          > > > > Yes, git grep MatPinToCPU shows stuff for ViennaCL but
>         not CUDA.
>          > > > > I guess I can add something like this below. Do we need
>         to set the device methods? They are already set when this method
>         is set, right?
>          > > > > We need the equivalent of
>          > > > > static PetscErrorCode MatPinToCPU_SeqAIJViennaCL(Mat
>         A,PetscBool flg)
>          > > > >   PetscFunctionBegin;
>          > > > >   A->pinnedtocpu = flg;
>          > > > >   if (flg) {
>          > > > >     A->ops->mult           = MatMult_SeqAIJ;
>          > > > >     A->ops->multadd        = MatMultAdd_SeqAIJ;
>          > > > >     A->ops->assemblyend    = MatAssemblyEnd_SeqAIJ;
>          > > > >     A->ops->duplicate      = MatDuplicate_SeqAIJ;
>          > > > >   } else {
>          > > > >     A->ops->mult           = MatMult_SeqAIJViennaCL;
>          > > > >     A->ops->multadd        = MatMultAdd_SeqAIJViennaCL;
>          > > > >     A->ops->assemblyend    = MatAssemblyEnd_SeqAIJViennaCL;
>          > > > >     A->ops->destroy        = MatDestroy_SeqAIJViennaCL;
>          > > > >     A->ops->duplicate      = MatDuplicate_SeqAIJViennaCL;
>          > > > > for MPIViennaCL and MPISeqAIJ Cusparse but it doesn't
>         look like it has been written yet.
>          > > > > > It does not seem to work. It does not look like CUDA
>         has an MatCreateVecs. Should I add one and copy this flag over?
>          > > > >    We do need this function. But I don't see how it
>         relates to pinning. When the matrix is pinned to the CPU we want
>         it to create CPU vectors which I assume it does.
>          > > > > > Mark
