[petsc-dev] MatPinToCPU
Mark Adams mfadams at lbl.gov
Sat Jul 27 10:40:39 CDT 2019
Yea, I just figured out the problem. VecDuplicate_MPICUDA did not call
PinToCPU or even copy pinnedtocpu. It just copied ops, so I added and am
testing:
  ierr = VecCreate_MPICUDA_Private(*v,PETSC_TRUE,w->nghost,0);CHKERRQ(ierr);
  vw   = (Vec_MPI*)(*v)->data;
  ierr = PetscMemcpy((*v)->ops,win->ops,sizeof(struct
_VecOps));CHKERRQ(ierr);
*  ierr = VecPinToCPU(*v,win->pinnedtocpu);CHKERRQ(ierr);*
On Sat, Jul 27, 2019 at 11:33 AM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>   I don't understand the context. Once a vector is pinned to the CPU the
> flag should be PETSC_OFFLOAD_CPU permanently until the pin to cpu is turned
> off.  Do you have a pinned vector that has the value PETSC_OFFLOAD_GPU?
> For example here it is set to PETSC_OFFLOAD_CPU
> PetscErrorCode VecPinToCPU_MPICUDA(Vec V,PetscBool pin)
>   if (pin) {
>     ierr = VecCUDACopyFromGPU(V);CHKERRQ(ierr);
>     V->valid_GPU_array = PETSC_OFFLOAD_CPU; /* since the CPU code will
> likely change values in the vector */
>   Is there any way to reproduce the problem?
>   Barry
> > On Jul 27, 2019, at 10:28 AM, Mark Adams <mfadams at lbl.gov> wrote:
> > I'm not sure what to do here. The problem is that pinned-to-cpu vectors
> are calling VecCUDACopyFromGPU here.
> > Should I set x->valid_GPU_array to something else, like
> PETSC_OFFLOAD_CPU, in PinToCPU so this block of code i s not executed?
> > PetscErrorCode VecGetArray(Vec x,PetscScalar **a)
> >   PetscErrorCode ierr;
> > #if defined(PETSC_HAVE_VIENNACL)
> >   PetscBool      is_viennacltype = PETSC_FALSE;
> > #endif
> >   PetscFunctionBegin;
> >   PetscValidHeaderSpecific(x,VEC_CLASSID,1);
> >   ierr = VecSetErrorIfLocked(x,1);CHKERRQ(ierr);
> >   if (x->petscnative) {
> > #if defined(PETSC_HAVE_VIENNACL) || defined(PETSC_HAVE_CUDA)
> >     if (x->valid_GPU_array == PETSC_OFFLOAD_GPU) {
> >       ierr =
> PetscObjectTypeCompareAny((PetscObject)x,&is_viennacltype,VECSEQVIENNACL,VECMPIVIENNACL,VECVIENNACL,"");CHKERRQ(ierr);
> >       if (is_viennacltype) {
> >         ierr = VecViennaCLCopyFromGPU(x);CHKERRQ(ierr);
> >       } else
> > #endif
> > #if defined(PETSC_HAVE_CUDA)
> >         ierr = VecCUDACopyFromGPU(x);CHKERRQ(ierr);
> > #endif
> >     } else if (x->valid_GPU_array == PETSC_OFFLOAD_UNALLOCATED) {
> >       ierr =
> >         ierr = VecViennaCLAllocateCheckHost(x);CHKERRQ(ierr);
> >       } else
> > #endif
> >         ierr = VecCUDAAllocateCheckHost(x);CHKERRQ(ierr);
> > #endif
> > #endif
> >     *a = *((PetscScalar**)x->data);
> >   } else {
> > On Tue, Jul 23, 2019 at 9:18 PM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> >  Yes, it needs to be able to switch back and forth between the CPU and
> GPU methods so you need to move into it the setting of the methods that is
> currently directly in the create method. See how
> MatConvert_SeqAIJ_SeqAIJViennaCL() calls ierr =
> MatPinToCPU_SeqAIJViennaCL(A,PETSC_FALSE);CHKERRQ(ierr); to set the methods
> for the GPU initially.
> >   Barry
> > > On Jul 23, 2019, at 7:32 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > >   What are the symptoms of it not working? Does it appear to be still
> copying the matrices to the GPU? then running the functions on the GPU?
> > > The object is dispatching the CUDA mat-vec etc.
> > >   I suspect the pinning is incompletely done for CUDA (and MPIOpenCL)
> matrices.
> > > Yes, git grep MatPinToCPU shows stuff for ViennaCL but not CUDA.
> > > I guess I can add something like this below. Do we need to set the
> device methods? They are already set when this method is set, right?
> > > We need the equivalent of
> > > static PetscErrorCode MatPinToCPU_SeqAIJViennaCL(Mat A,PetscBool flg)
> > >   PetscFunctionBegin;
> > >   A->pinnedtocpu = flg;
> > >   if (flg) {
> > >     A->ops->mult           = MatMult_SeqAIJ;
> > >     A->ops->multadd        = MatMultAdd_SeqAIJ;
> > >     A->ops->assemblyend    = MatAssemblyEnd_SeqAIJ;
> > >     A->ops->duplicate      = MatDuplicate_SeqAIJ;
> > >   } else {
> > >     A->ops->mult           = MatMult_SeqAIJViennaCL;
> > >     A->ops->multadd        = MatMultAdd_SeqAIJViennaCL;
> > >     A->ops->assemblyend    = MatAssemblyEnd_SeqAIJViennaCL;
> > >     A->ops->destroy        = MatDestroy_SeqAIJViennaCL;
> > >     A->ops->duplicate      = MatDuplicate_SeqAIJViennaCL;
> > >   PetscFunctionReturn(0);
> > > for MPIViennaCL and MPISeqAIJ Cusparse but it doesn't look like it has
> been written yet.
> > > > It does not seem to work. It does not look like CUDA has an
> MatCreateVecs. Should I add one and copy this flag over?
> > >    We do need this function. But I don't see how it relates to
> pinning. When the matrix is pinned to the CPU we want it to create CPU
> vectors which I assume it does.
> > > > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190727/9e4a4fe0/attachment-0001.html>
