[petsc-dev] MatPinToCPU
Mark Adams
mfadams at lbl.gov
Sat Jul 27 10:28:17 CDT 2019
I'm not sure what to do here. The problem is that pinned-to-cpu vectors are
calling *VecCUDACopyFromGPU* here.
Should I set *x->valid_GPU_array *to something else, like
PETSC_OFFLOAD_CPU, in PinToCPU so this block of code i s not executed?
PetscErrorCode VecGetArray(Vec x,PetscScalar **a)
PetscErrorCode ierr;
#if defined(PETSC_HAVE_VIENNACL)
PetscBool is_viennacltype = PETSC_FALSE;
#endif
PetscFunctionBegin;
PetscValidHeaderSpecific(x,VEC_CLASSID,1);
ierr = VecSetErrorIfLocked(x,1);CHKERRQ(ierr);
if (x->petscnative) {
#if defined(PETSC_HAVE_VIENNACL) || defined(PETSC_HAVE_CUDA)
if (*x->valid_GPU_array* == PETSC_OFFLOAD_GPU) {
ierr =
PetscObjectTypeCompareAny((PetscObject)x,&is_viennacltype,VECSEQVIENNACL,VECMPIVIENNACL,VECVIENNACL,"");CHKERRQ(ierr);
if (is_viennacltype) {
ierr = VecViennaCLCopyFromGPU(x);CHKERRQ(ierr);
} else
#endif
#if defined(PETSC_HAVE_CUDA)
* ierr = VecCUDACopyFromGPU(x);CHKERRQ(ierr);*#endif
} else if (x->valid_GPU_array == PETSC_OFFLOAD_UNALLOCATED) {
ierr =
ierr = VecViennaCLAllocateCheckHost(x);CHKERRQ(ierr);
} else
#endif
ierr = VecCUDAAllocateCheckHost(x);CHKERRQ(ierr);
#endif
#endif
*a = *((PetscScalar**)x->data);
} else {
On Tue, Jul 23, 2019 at 9:18 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> Yes, it needs to be able to switch back and forth between the CPU and GPU
> methods so you need to move into it the setting of the methods that is
> currently directly in the create method. See how
> MatConvert_SeqAIJ_SeqAIJViennaCL() calls ierr =
> MatPinToCPU_SeqAIJViennaCL(A,PETSC_FALSE);CHKERRQ(ierr); to set the methods
> for the GPU initially.
> Barry
> > On Jul 23, 2019, at 7:32 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > What are the symptoms of it not working? Does it appear to be still
> copying the matrices to the GPU? then running the functions on the GPU?
> > The object is dispatching the CUDA mat-vec etc.
> > I suspect the pinning is incompletely done for CUDA (and MPIOpenCL)
> matrices.
> > Yes, git grep MatPinToCPU shows stuff for ViennaCL but not CUDA.
> > I guess I can add something like this below. Do we need to set the
> device methods? They are already set when this method is set, right?
> > We need the equivalent of
> > static PetscErrorCode MatPinToCPU_SeqAIJViennaCL(Mat A,PetscBool flg)
> > PetscFunctionBegin;
> > A->pinnedtocpu = flg;
> > if (flg) {
> > A->ops->mult = MatMult_SeqAIJ;
> > A->ops->multadd = MatMultAdd_SeqAIJ;
> > A->ops->assemblyend = MatAssemblyEnd_SeqAIJ;
> > A->ops->duplicate = MatDuplicate_SeqAIJ;
> > } else {
> > A->ops->mult = MatMult_SeqAIJViennaCL;
> > A->ops->multadd = MatMultAdd_SeqAIJViennaCL;
> > A->ops->assemblyend = MatAssemblyEnd_SeqAIJViennaCL;
> > A->ops->destroy = MatDestroy_SeqAIJViennaCL;
> > A->ops->duplicate = MatDuplicate_SeqAIJViennaCL;
> > PetscFunctionReturn(0);
> > for MPIViennaCL and MPISeqAIJ Cusparse but it doesn't look like it has
> been written yet.
> > > It does not seem to work. It does not look like CUDA has an
> MatCreateVecs. Should I add one and copy this flag over?
> > We do need this function. But I don't see how it relates to pinning.
> When the matrix is pinned to the CPU we want it to create CPU vectors which
> I assume it does.
> > > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190727/9c597e73/attachment.html>
