> On Jul 23, 2019, at 9:12 AM, Mark Adams via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> I've tried to add pining the matrix and prolongator to the CPU on coarse grids in GAMG with this:
> /* pin reduced coase grid - could do something smarter */
> ierr = MatPinToCPU(*a_Amat_crs,PETSC_TRUE);CHKERRQ(ierr);
> ierr = MatPinToCPU(*a_P_inout,PETSC_TRUE);CHKERRQ(ierr);
What are the symptoms of it not working? Does it appear to be still copying the matrices to the GPU? then running the functions on the GPU?
I suspect the pinning is incompletely done for CUDA (and MPIOpenCL) matrices.
We need the equivalent of
static PetscErrorCode MatPinToCPU_SeqAIJViennaCL(Mat A,PetscBool flg)
PetscFunctionBegin;
A->pinnedtocpu = flg;
if (flg) {
A->ops->mult = MatMult_SeqAIJ;
A->ops->multadd = MatMultAdd_SeqAIJ;
A->ops->assemblyend = MatAssemblyEnd_SeqAIJ;
A->ops->duplicate = MatDuplicate_SeqAIJ;
} else {
A->ops->mult = MatMult_SeqAIJViennaCL;
A->ops->multadd = MatMultAdd_SeqAIJViennaCL;
A->ops->assemblyend = MatAssemblyEnd_SeqAIJViennaCL;
A->ops->destroy = MatDestroy_SeqAIJViennaCL;
A->ops->duplicate = MatDuplicate_SeqAIJViennaCL;
PetscFunctionReturn(0);
for MPIViennaCL and MPISeqAIJ Cusparse but it doesn't look like it has been written yet.
> It does not seem to work. It does not look like CUDA has an MatCreateVecs. Should I add one and copy this flag over?
We do need this function. But I don't see how it relates to pinning. When the matrix is pinned to the CPU we want it to create CPU vectors which I assume it does.
> Mark
