[petsc-dev] Fwd: [mumps-users] MUMPS MPI (5.2.1) does not compile
Smith, Barry F. bsmith at mcs.anl.gov
Mon Jul 22 13:54:03 CDT 2019
  Pierre,
   I see four patches here.
1) for examples
2) for shared library support (but only for Linux????) (two files for MUMPS and PORD) We can't use this unless also supports Mac etc
3) MUMPS-Makefile.par.inc  What is this for?
  How does any of them resolve the problem with ifort failing to compile?
  Barry
> On Jul 22, 2019, at 1:28 PM, Pierre Jolivet via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> We are having trouble compiling git.mumps with similar errors (using ifort 2017, yikes).
> Could the forwarded patches be applied to petsc/pkg-mumps, please?
> Thanks in advance (and sorry if this should be handled @petsc-maint),
> Pierre
>> Begin forwarded message:
>> From: "Antonio Trande" (anto.trande at gmail.com via mumps-users Mailing List) <mumps-users at listes.ens-lyon.fr>
>> Subject: [mumps-users] MUMPS MPI (5.2.1) does not compile
>> Date: 29 June 2019 at 5:56:28 PM CEST
>> To: "mumps-users at listes.ens-lyon.fr" <mumps-users at listes.ens-lyon.fr>
>> Reply-To: mumps-users at listes.ens-lyon.fr
>> Hi all.
>> MUMPS-5.2.1 is not compiling on Fedora 30 because of this error:
>> /usr/lib64/openmpi/bin/mpif77 -O2 -g -pipe -Wall -Werror=format-security
>> -Wp,-D_FORTIFY_SOURCE=2 -Wp,-D_GLIBCXX_ASSERTIONS -fexceptions
>> -fstack-protector-strong -grecord-gcc-switches
>> -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1
>> -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1 -m64 -mtune=generic
>> -fasynchronous-unwind-tables -fstack-clash-protection -fcf-protection
>> -Dscotch -Dmetis -Dptscotch -pthread -I/usr/lib64/gfortran/modules
>> -Dintel_ -Wno-unused-dummy-argument -Wno-maybe-uninitialized
>> -I/usr/include/openmpi-x86_64 -I/usr/include/openblas
>> -I/usr/include/openmpi-x86_64 -Dpord -I. -I../include -fPIC -c
>> cmumps_save_restore.F -o cmumps_save_restore.o
>> cmumps_save_restore.F:8105:50:
>> 8105 |                IF(associated(id%MPITOOMP_PROCS_MAP)) THEN
>>      |                                                  1
>> Error: 'mpitoomp_procs_map' at (1) is not a member of the 'cmumps_struc'
>> structure
>> cmumps_save_restore.F:8108:49:
>> 8108 |      &                 size(id%MPITOOMP_PROCS_MAP,1)*SIZE_INT
>>      |                                                 1
>> structure
>> cmumps_save_restore.F:8113:72:
>> 8113 |             elseif(trim(mode).EQ."save") then
>>       1
>> Error: Unexpected ELSE IF statement at (1)
>> cmumps_save_restore.F:8114:50:
>> 8114 |                IF(associated(id%MPITOOMP_PROCS_MAP)) THEN
>>      |                                                  1
>> structure
>> cmumps_save_restore.F:8115:67:
>> 8115 |                   write(unit,iostat=err)
>>      |        1
>> structure
>> cmumps_save_restore.F:8124:62:
>> 8124 |                   write(unit,iostat=err) id%MPITOOMP_PROCS_MAP
>>      |                                                              1
>> structure
>> cmumps_save_restore.F:8125:72:
>> 8125 |                ELSE
>>       1
>> Error: Unexpected ELSE statement at (1)
>> cmumps_save_restore.F:8136:18:
>> 8136 |                ENDIF
>>      |                  1
>> Error: Expecting END SELECT statement at (1)
>> cmumps_save_restore.F:8145:72:
>> 8145 |             elseif(trim(mode).EQ."restore") then
>>       1
>> cmumps_save_restore.F:8146:44:
>> 8146 |                nullify(id%MPITOOMP_PROCS_MAP)
>>      |                                            1
>> structure
>> cmumps_save_restore.F:8163:48:
>> 8163 |                   allocate(id%MPITOOMP_PROCS_MAP(size_array1),
>>      |                                                1
>> structure
>> cmumps_save_restore.F:8171:61:
>> 8171 |                   read(unit,iostat=err) id%MPITOOMP_PROCS_MAP
>>      |                                                             1
>> structure
>> cmumps_save_restore.F:8184:15:
>> 8184 |             endif
>>      |               1
>> cmumps_save_restore.F:8188:64:
>> 8188 |                SIZE_VARIABLES(i1)=SIZE_INT*size(id%METIS_OPTIONS,1)
>>      |        1
>> Error: 'metis_options' at (1) is not a member of the 'cmumps_struc'
>> structure
>> cmumps_save_restore.F:8190:54:
>> 8190 |                write(unit,iostat=err) id%METIS_OPTIONS
>>      |                                                      1
>> structure
>> cmumps_save_restore.F:8200:64:
>> 8200 |                SIZE_VARIABLES(i1)=SIZE_INT*size(id%METIS_OPTIONS,1)
>>      |        1
>> structure
>> cmumps_save_restore.F:8201:53:
>> 8201 |                read(unit,iostat=err) id%METIS_OPTIONS
>>      |                                                     1
>> structure
>> make[3]: *** [Makefile:396: cmumps_save_restore.o] Error 1
>> I'm patching MUMPS for compiling shared libraries for Fedora. I'm
>> attaching the patch used.
>> Antonio Trande
>> Fedora Project
>> mailto 'sagitter at fedoraproject dot org'
>> GPG key: 0x6e0331dd1699e4d7
>> GPG key server: https://keys.fedoraproject.org/
>> Subscription/unsubscription: see https://listes.ens-lyon.fr/sympa/subscribe/mumps-users
> <MUMPS-examples-mpilibs.patch><MUMPS-Makefile.par.inc><MUMPS-shared.patch><MUMPS-shared-pord.patch>
