[petsc-dev] (no subject)
Stefano Zampini
stefano.zampini at gmail.com
Mon Jul 22 07:28:46 CDT 2019
I just checked, and this is a bug also in maint.
Il giorno lun 22 lug 2019 alle ore 13:23 Stefano Zampini via petsc-dev <
petsc-dev at mcs.anl.gov> ha scritto:
> Junchao,
> I found an issue with PetscSFReduceBegin/End. It seems that we can no
> longer do (always worked before)
> ierr = PetscSFReduceBegin(sf,MPIU_INT,leaf,root,MPI_MAX);CHKERRQ(ierr);
> ierr =
> PetscSFReduceBegin(sf,MPIU_INT,leaf2,root2,MPI_MAX);CHKERRQ(ierr);
> ierr = PetscSFReduceEnd(sf,MPIU_INT,leaf,root,MPI_MAX);CHKERRQ(ierr);
> ierr = PetscSFReduceEnd(sf,MPIU_INT,leaf2,root2,MPI_MAX);CHKERRQ(ierr);
> You can reproduce with the currrent master
> $ cd $PETSC_DIR/src/ksp/ksp/examples/tutorials
> $ make ex71
> $ mpiexec -n 4 ./ex71 -pde_type Elasticity -cells 7,9 -dim 2
> -pc_bddc_levels 1 -pc_bddc_coarsening_ratio 2 -ksp_error_if_not_converged
> -pc_bddc_monolithic -pc_bddc_use_faces
> -pc_bddc_coarse_pc_bddc_corner_selection
> -pc_bddc_coarse_l1_pc_bddc_corner_selection -mat_partitioning_type average
> -pc_bddc_coarse_pc_bddc_use_deluxe_scaling
> -pc_bddc_coarse_sub_schurs_mat_solver_type petsc
> The attached patch shows that if we instead do
> ierr =
> everything works properly.
> I think the issue is with the SF GetPack mechanism, but I couldn't figure
> out where.
> Stefano
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190722/1c05f2fa/attachment.html>
