[petsc-dev] Fwd: PETSc blame digest (next-tmp) 2019-07-17
    Balay, Satish
    balay at mcs.anl.gov
    Wed Jul 17 17:52:20 CDT 2019
Note: We had disabled c++ PETSc builds on opensolaris [as we didn't
want to deal with some of the c++ warnings from this compiler]
Presumably all these issues will come up with c++ test codes using the
usual c build of PETSc. [as you say - this example's scope is limited
to petscmat.h - so issues with other includes are not yet visible in
this mode].
So perhaps we should also disable cxx examples on opensolaris? [Don't
know how to implement this yet]
I think we cannot use --with-cxx=0 as some of the externalpackages
might need the c++ compiler.
Satish
On Wed, 17 Jul 2019, Zhang, Junchao wrote:
> Fande did a fantastic job using C++11 in the test code. I modified it so it does not use C++11 anymore. But I think Satish's code is still useful and we should have it in a
> new PR.
> Another serious issue using Sun C++ with this C++ test code:
> "/export/home/jczhang/petsc/include/petscmat.h", line 153: Warning (Anachronism): Formal argument 4 of type extern "C" int(*)(_p_Mat*,MatFactorType,_p_Mat**) in call to
> MatSolverTypeRegister(const char*, const char*, MatFactorType, extern "C" int(*)(_p_Mat*,MatFactorType,_p_Mat**)) is being passed int(*)(_p_Mat*,MatFactorType,_p_Mat**).
> "/export/home/jczhang/petsc/include/petscmat.h", line 155: Error: Formal argument 6 of type extern "C" int(*)(_p_Mat*,MatFactorType,_p_Mat**)* in call to
> MatSolverTypeGet(const char*, const char*, MatFactorType, PetscBool*, PetscBool*, extern "C" int(*)(_p_Mat*,MatFactorType,_p_Mat**)*) is being passed
> int(*)(_p_Mat*,MatFactorType,_p_Mat**)*.
> 1 Error(s) and 1 Warning(s) detected.
> Googled and found it only happens to Sun compilers. The logic is
> we have
> PETSC_EXTERN PetscErrorCode MatSolverTypeRegister(MatSolverType,MatType,MatFactorType,PetscErrorCode(*)(Mat,MatFactorType,Mat*));
> Sun C++ thinks the function pointer argument is in C linkage.
> We also have
> PETSC_DEPRECATED_FUNCTION("Use MatSolverTypeRegister() (since version 3.9)") PETSC_STATIC_INLINE PetscErrorCode MatSolverPackageRegister(MatSolverType stype,MatType
> mtype,MatFactorType ftype,PetscErrorCode(*f)(Mat,MatFactorType,Mat*))
> { return MatSolverTypeRegister(stype,mtype,ftype,f); }
> Without PETSC_EXTERN, Sun C++ thinks the function pointer argument is in C++ linkage. This mismatch caused the warning and errors. I have to add PETSC_EXTERN in petscmat.h
> to get rid of them.  Other header files may also have this problem, but thanks to Fande for only including petscmat.h :)
> diff --git a/include/petscmat.h b/include/petscmat.h
> index 95c2b825..08300bc2 100644
> --- a/include/petscmat.h
> +++ b/include/petscmat.h
> @@ -149,9 +149,9 @@ PETSC_EXTERN PetscErrorCode MatSetFactorType(Mat,MatFactorType);
>  PETSC_EXTERN PetscErrorCode MatSolverTypeGet(MatSolverType,MatType,MatFactorType,PetscBool*,PetscBool*,PetscErrorCode (**)(Mat,MatFactorType,Mat*));
>  typedef MatSolverType MatSolverPackage PETSC_DEPRECATED_TYPEDEF("Use MatSolverType (since version 3.9)");
> -PETSC_DEPRECATED_FUNCTION("Use MatSolverTypeRegister() (since version 3.9)") PETSC_STATIC_INLINE PetscErrorCode MatSolverPackageRegister(MatSolverType stype,MatType
> +PETSC_DEPRECATED_FUNCTION("Use MatSolverTypeRegister() (since version 3.9)") PETSC_EXTERN PETSC_STATIC_INLINE PetscErrorCode MatSolverPackageRegister(MatSolverType
> stype,MatType mtype,MatFactorType ftype,PetscErrorCode(*f)(Mat,MatFactorType,Mat*))
> -PETSC_DEPRECATED_FUNCTION("Use MatSolverTypeGet() (since version 3.9)") PETSC_STATIC_INLINE PetscErrorCode MatSolverPackageGet(MatSolverType stype,MatType
> mtype,MatFactorType ftype,PetscBool *foundmtype,PetscBool *foundstype,PetscErrorCode(**f)(Mat,MatFactorType,Mat*))
> +PETSC_DEPRECATED_FUNCTION("Use MatSolverTypeGet() (since version 3.9)") PETSC_EXTERN PETSC_STATIC_INLINE PetscErrorCode MatSolverPackageGet(MatSolverType stype,MatType
>  { return MatSolverTypeGet(stype,mtype,ftype,foundmtype,foundstype,f); }
> --Junchao Zhang
> On Wed, Jul 17, 2019 at 5:06 PM Balay, Satish <balay at mcs.anl.gov> wrote:
>       Perhaps you can use the following in your PR? But then - you have to check for both PETSC_CXX_DIALECT_CXX14 and PETSC_CXX_DIALECT_CXX11 in your code.
>       #define PETSC_CXX_DIALECT_CXX14 1
>       diff --git a/config/BuildSystem/config/compilers.py b/config/BuildSystem/config/compilers.py
>       index c29cc2a67a..4775318a7d 100644
>       --- a/config/BuildSystem/config/compilers.py
>       +++ b/config/BuildSystem/config/compilers.py
>       @@ -525,6 +525,8 @@ class Configure(config.base.Configure):
>            self.setCompilers.popLanguage()
>            self.logWrite(self.setCompilers.restoreLog())
>       +    if self.cxxdialect:
>       +      self.addDefine('CXX_DIALECT_'+self.cxxdialect.upper().replace('+','X'),1)
>            return
>          def checkCxxLibraries(self):
>       Or does the following make more sense? [but I suspect this is useful
>       for CPP which supports '>' etc.. comparison operations - but perhaps
>       not the test suite]
>       #define PETSC_CXX_DIALECT 14
>       index c29cc2a67a..b391e4a3b0 100644
>       +      self.addDefine('CXX_DIALECT',self.cxxdialect.upper().replace('C++',''))
>            return
>       cc: Barry
>       Satish
>       > Do we have things like PETSC_HAVE_C++11 ?
>       > --Junchao Zhang
>       > ---------- Forwarded message ---------
>       > From: PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov>
>       > Date: Wed, Jul 17, 2019 at 3:28 PM
>       > Subject: PETSc blame digest (next-tmp) 2019-07-17
>       > To: Junchao Zhang <jczhang at mcs.anl.gov>, PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov>
>       > Dear PETSc developer,
>       > This email contains listings of contributions attributed to you by
>       > `git blame` that caused compiler errors or warnings in PETSc automated
>       > testing.  Follow the links to see the full log files. Please attempt to fix
>       > the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are unable
>       > to resolve the issues.
>       > Thanks,
>       >   The PETSc development team
>       > warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/da92d23
>       > Add a benchmark for MatAssembly from the Moose project
>       >   src/sys/examples/tests/ex53.cxx:102
>       >     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs//archive/2019/07/17/examples_next-tmp_arch-opensolaris-misc_n-gage.log]
>       >       "/export/home/petsc/petsc.next-tmp-2/src/sys/examples/tests/ex53.cxx", line 102: Error: "," expected instead of ":".
>       >     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs//archive/2019/07/17/examples_next-tmp_arch-opensolaris-pkgs-opt_n-gage.log]
>       >       "/export/home/petsc/petsc.next-tmp/src/sys/examples/tests/ex53.cxx", line 102: Error: "," expected instead of ":".
>       >       "/export/home/petsc/petsc.next-tmp/src/sys/examples/tests/ex53.cxx", line 102: Error: Use ";" to terminate declarations.
>       >     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs//archive/2019/07/17/examples_next-tmp_arch-opensolaris-cmplx-pkgs-dbg_n-gage.log]
>       >       "/export/home/petsc/petsc.next-tmp-3/src/sys/examples/tests/ex53.cxx", line 102: Error: Use ";" to terminate declarations.
>       >       "/export/home/petsc/petsc.next-tmp-2/src/sys/examples/tests/ex53.cxx", line 102: Error: Expected an expression.
>       >       "/export/home/petsc/petsc.next-tmp-3/src/sys/examples/tests/ex53.cxx", line 102: Error: Expected an expression.
>       >       "/export/home/petsc/petsc.next-tmp-3/src/sys/examples/tests/ex53.cxx", line 102: Error: "," expected instead of ":".
>       >       "/export/home/petsc/petsc.next-tmp-2/src/sys/examples/tests/ex53.cxx", line 102: Error: Use ";" to terminate declarations.
>       >       "/export/home/petsc/petsc.next-tmp/src/sys/examples/tests/ex53.cxx", line 102: Error: Expected an expression.
>       >   src/sys/examples/tests/ex53.cxx:103
>       >       "/export/home/petsc/petsc.next-tmp/src/sys/examples/tests/ex53.cxx", line 103: Warning: The variable dof has not yet been assigned a value.
>       >       "/export/home/petsc/petsc.next-tmp-2/src/sys/examples/tests/ex53.cxx", line 103: Warning: The variable dof has not yet been assigned a value.
>       >       "/export/home/petsc/petsc.next-tmp-3/src/sys/examples/tests/ex53.cxx", line 103: Warning: The variable dof has not yet been assigned a value.
>       >   src/sys/examples/tests/ex53.cxx:132
>       >       "/export/home/petsc/petsc.next-tmp-2/src/sys/examples/tests/ex53.cxx", line 132: Error: data is not a member of std::vector<long long>.
>       >       "/export/home/petsc/petsc.next-tmp/src/sys/examples/tests/ex53.cxx", line 132: Error: data is not a member of std::vector<int>.
>       >       "/export/home/petsc/petsc.next-tmp-3/src/sys/examples/tests/ex53.cxx", line 132: Error: data is not a member of std::vector<int>.
>       >   src/sys/examples/tests/ex53.cxx:133
>       >       "/export/home/petsc/petsc.next-tmp/src/sys/examples/tests/ex53.cxx", line 133: Error: data is not a member of std::vector<int>.
>       >       "/export/home/petsc/petsc.next-tmp-2/src/sys/examples/tests/ex53.cxx", line 133: Error: data is not a member of std::vector<long long>.
>       >       "/export/home/petsc/petsc.next-tmp-3/src/sys/examples/tests/ex53.cxx", line 133: Error: data is not a member of std::vector<int>.
>       >   src/sys/examples/tests/ex53.cxx:137
>       >       "/export/home/petsc/petsc.next-tmp-2/src/sys/examples/tests/ex53.cxx", line 137: Error: Use ";" to terminate declarations.
>       >       "/export/home/petsc/petsc.next-tmp-3/src/sys/examples/tests/ex53.cxx", line 137: Error: Use ";" to terminate declarations.
>       >       "/export/home/petsc/petsc.next-tmp-2/src/sys/examples/tests/ex53.cxx", line 137: Error: dof_indices must be initialized.
>       >       "/export/home/petsc/petsc.next-tmp-2/src/sys/examples/tests/ex53.cxx", line 137: Error: Expected an expression.
>       >       "/export/home/petsc/petsc.next-tmp-3/src/sys/examples/tests/ex53.cxx", line 137: Error: Expected an expression.
>       >       "/export/home/petsc/petsc.next-tmp-3/src/sys/examples/tests/ex53.cxx", line 137: Error: "," expected instead of ":".
>       >       "/export/home/petsc/petsc.next-tmp/src/sys/examples/tests/ex53.cxx", line 137: Error: dof_indices must be initialized.
>       >       "/export/home/petsc/petsc.next-tmp/src/sys/examples/tests/ex53.cxx", line 137: Error: "," expected instead of ":".
>       >       "/export/home/petsc/petsc.next-tmp/src/sys/examples/tests/ex53.cxx", line 137: Error: Expected an expression.
>       >       "/export/home/petsc/petsc.next-tmp-2/src/sys/examples/tests/ex53.cxx", line 137: Error: "," expected instead of ":".
>       >       "/export/home/petsc/petsc.next-tmp-3/src/sys/examples/tests/ex53.cxx", line 137: Error: dof_indices must be initialized.
>       >       "/export/home/petsc/petsc.next-tmp/src/sys/examples/tests/ex53.cxx", line 137: Error: Use ";" to terminate declarations.
>       >   src/sys/examples/tests/ex53.cxx:140
>       >       "/export/home/petsc/petsc.next-tmp-2/src/sys/examples/tests/ex53.cxx", line 140: Error: int is not a structure type.
>       >       "/export/home/petsc/petsc.next-tmp-3/src/sys/examples/tests/ex53.cxx", line 140: Error: int is not a structure type.
>       >       "/export/home/petsc/petsc.next-tmp/src/sys/examples/tests/ex53.cxx", line 140: Error: int is not a structure type.
>       >   src/sys/examples/tests/ex53.cxx:64
>       >       "/export/home/petsc/petsc.next-tmp-2/src/sys/examples/tests/ex53.cxx", line 64: Error: Cannot use const std::string  to initialize std::ifstream .
>       >       "/export/home/petsc/petsc.next-tmp-3/src/sys/examples/tests/ex53.cxx", line 64: Error: Cannot use const std::string  to initialize std::ifstream .
>       >       "/export/home/petsc/petsc.next-tmp/src/sys/examples/tests/ex53.cxx", line 64: Error: Cannot use const std::string  to initialize std::ifstream .
>       >   src/sys/examples/tests/ex53.cxx:68
>       >       "/export/home/petsc/petsc.next-tmp-2/src/sys/examples/tests/ex53.cxx", line 68: Error: In this declaration "sstream" is of an incomplete type
>       "std::stringstream ".
>       >       "/export/home/petsc/petsc.next-tmp-2/src/sys/examples/tests/ex53.cxx", line 68: Error: The type "std::stringstream " is incomplete.
>       >       "/export/home/petsc/petsc.next-tmp/src/sys/examples/tests/ex53.cxx", line 68: Error: In this declaration "sstream" is of an incomplete type
>       >       "/export/home/petsc/petsc.next-tmp-3/src/sys/examples/tests/ex53.cxx", line 68: Error: In this declaration "sstream" is of an incomplete type
>       >       "/export/home/petsc/petsc.next-tmp-3/src/sys/examples/tests/ex53.cxx", line 68: Error: The type "std::stringstream " is incomplete.
>       >       "/export/home/petsc/petsc.next-tmp/src/sys/examples/tests/ex53.cxx", line 68: Error: The type "std::stringstream " is incomplete.
>       >   src/sys/examples/tests/ex53.cxx:70
>       >       "/export/home/petsc/petsc.next-tmp/src/sys/examples/tests/ex53.cxx", line 70: Error: Could not find a match for std::getline<std::_charT, std::_Traits,
>       > std::_Allocator>(std::stringstream, std::string, char) needed in main(int, char**).
>       >       "/export/home/petsc/petsc.next-tmp-3/src/sys/examples/tests/ex53.cxx", line 70: Error: stoi is not a member of std.
>       >       "/export/home/petsc/petsc.next-tmp-2/src/sys/examples/tests/ex53.cxx", line 70: Error: stoi is not a member of std.
>       >       "/export/home/petsc/petsc.next-tmp-2/src/sys/examples/tests/ex53.cxx", line 70: Error: Could not find a match for std::getline<std::_charT,
>       std::_Traits,
>       >       "/export/home/petsc/petsc.next-tmp-3/src/sys/examples/tests/ex53.cxx", line 70: Error: Could not find a match for std::getline<std::_charT,
>       std::_Traits,
>       >       "/export/home/petsc/petsc.next-tmp/src/sys/examples/tests/ex53.cxx", line 70: Error: stoi is not a member of std.
>       >   src/sys/examples/tests/ex53.cxx:91
>       >       "/export/home/petsc/petsc.next-tmp-3/src/sys/examples/tests/ex53.cxx", line 91: Error: "," expected instead of ":".
>       >       "/export/home/petsc/petsc.next-tmp-2/src/sys/examples/tests/ex53.cxx", line 91: Error: "," expected instead of ":".
>       >       "/export/home/petsc/petsc.next-tmp/src/sys/examples/tests/ex53.cxx", line 91: Error: "," expected instead of ":".
>       >       "/export/home/petsc/petsc.next-tmp-3/src/sys/examples/tests/ex53.cxx", line 91: Error: dof_indices must be initialized.
>       >       "/export/home/petsc/petsc.next-tmp-2/src/sys/examples/tests/ex53.cxx", line 91: Error: dof_indices must be initialized.
>       >       "/export/home/petsc/petsc.next-tmp/src/sys/examples/tests/ex53.cxx", line 91: Error: dof_indices must be initialized.
>       >   src/sys/examples/tests/ex53.cxx:92
>       >       "/export/home/petsc/petsc.next-tmp/src/sys/examples/tests/ex53.cxx", line 92: Error: Expected an expression.
>       >       "/export/home/petsc/petsc.next-tmp/src/sys/examples/tests/ex53.cxx", line 92: Error: int is not a structure type.
>       >       "/export/home/petsc/petsc.next-tmp-2/src/sys/examples/tests/ex53.cxx", line 92: Error: Expected an expression.
>       >       "/export/home/petsc/petsc.next-tmp-2/src/sys/examples/tests/ex53.cxx", line 92: Error: Use ";" to terminate declarations.
>       >       "/export/home/petsc/petsc.next-tmp-3/src/sys/examples/tests/ex53.cxx", line 92: Error: int is not a structure type.
>       >       "/export/home/petsc/petsc.next-tmp/src/sys/examples/tests/ex53.cxx", line 92: Error: Use ";" to terminate declarations.
>       >       "/export/home/petsc/petsc.next-tmp-2/src/sys/examples/tests/ex53.cxx", line 92: Error: int is not a structure type.
>       >       "/export/home/petsc/petsc.next-tmp-3/src/sys/examples/tests/ex53.cxx", line 92: Error: Expected an expression.
>       >       "/export/home/petsc/petsc.next-tmp-3/src/sys/examples/tests/ex53.cxx", line 92: Error: Use ";" to terminate declarations.
>       >   src/sys/examples/tests/ex53.cxx:93
>       >       "/export/home/petsc/petsc.next-tmp-2/src/sys/examples/tests/ex53.cxx", line 93: Error: int is not a structure type.
>       >       "/export/home/petsc/petsc.next-tmp-3/src/sys/examples/tests/ex53.cxx", line 93: Error: int is not a structure type.
>       >       "/export/home/petsc/petsc.next-tmp/src/sys/examples/tests/ex53.cxx", line 93: Error: int is not a structure type.
>       >   src/sys/examples/tests/ex53.cxx:94
>       >       "/export/home/petsc/petsc.next-tmp-3/src/sys/examples/tests/ex53.cxx", line 94: Error: Pointer type needed instead of int.
>       >       "/export/home/petsc/petsc.next-tmp/src/sys/examples/tests/ex53.cxx", line 94: Error: Pointer type needed instead of int.
>       >       "/export/home/petsc/petsc.next-tmp-2/src/sys/examples/tests/ex53.cxx", line 94: Error: Pointer type needed instead of int.
>       > To opt-out from receiving these messages - send a request to petsc-dev at mcs.anl.gov.
