[petsc-dev] Slowness of PetscSortIntWithArrayPair in MatAssembly
Zhang, Junchao
jczhang at mcs.anl.gov
Mon Jul 8 15:28:42 CDT 2019
Is the code public for me to test?
--Junchao Zhang
On Mon, Jul 8, 2019 at 3:06 PM Fande Kong <fdkong.jd at gmail.com<mailto:fdkong.jd at gmail.com>> wrote:
Thanks Junchao,
Tried your code. I did not hit seg fault this time, but the assembly was still slow
time mpirun -n 2 ./matrix_sparsity-opt -matstash_legacy
Close matrix for np = 2 ...
Matrix successfully closed
real 0m2.009s
user 0m3.324s
sys 0m0.575s
real 3m39.235s
user 6m42.184s
sys 0m35.084s
Fande,
On Mon, Jul 8, 2019 at 8:47 AM Fande Kong <fdkong.jd at gmail.com<mailto:fdkong.jd at gmail.com>> wrote:
Will let you know soon.
Fande,
On Mon, Jul 8, 2019 at 8:41 AM Zhang, Junchao <jczhang at mcs.anl.gov<mailto:jczhang at mcs.anl.gov>> wrote:
Fande or John,
Could any of you have a try? Thanks
--Junchao Zhang
---------- Forwarded message ---------
From: Junchao Zhang <jczhang at mcs.anl.gov<mailto:jczhang at mcs.anl.gov>>
Date: Thu, Jul 4, 2019 at 8:21 AM
Subject: Re: [petsc-dev] Slowness of PetscSortIntWithArrayPair in MatAssembly
To: Fande Kong <fdkong.jd at gmail.com<mailto:fdkong.jd at gmail.com>>
Fande,
I wrote tests but could not reproduce the error. I pushed a commit that changed the MEDIAN macro to a function to make it easier to debug. Could you run and debug it again? It should be easy to see what is wrong in gdb.
Thanks.
--Junchao Zhang
On Wed, Jul 3, 2019 at 6:48 PM Fande Kong <fdkong.jd at gmail.com<mailto:fdkong.jd at gmail.com>> wrote:
Process 3915 resuming
Process 3915 stopped
* thread #1, queue = 'com.apple.main-thread', stop reason = EXC_BAD_ACCESS (code=2, address=0x7ffee9b91fc8)
frame #0: 0x000000010cbaa031 libpetsc.3.011.dylib`PetscSortIntWithArrayPair_Private(L=0x0000000119fc5480, J=0x000000011bfaa480, K=0x000000011ff74480, right=13291) at sorti.c:298
295 }
296 PetscFunctionReturn(0);
297 }
-> 298 i = MEDIAN(L,right);
299 SWAP3(L[0],L[i],J[0],J[i],K[0],K[i],tmp);
300 vl = L[0];
301 last = 0;
(lldb)
On Wed, Jul 3, 2019 at 4:32 PM Zhang, Junchao <jczhang at mcs.anl.gov<mailto:jczhang at mcs.anl.gov>> wrote:
Could you debug it or paste the stack trace? Since it is a segfault, it should be easy.
--Junchao Zhang
On Wed, Jul 3, 2019 at 5:16 PM Fande Kong <fdkong.jd at gmail.com<mailto:fdkong.jd at gmail.com>> wrote:
Thanks Junchao,
But there is still segment fault. I guess you could write some continuous integers to test your changes.
Fande
On Wed, Jul 3, 2019 at 12:57 PM Zhang, Junchao <jczhang at mcs.anl.gov<mailto:jczhang at mcs.anl.gov>> wrote:
Fande and John,
Could you try jczhang/feature-better-quicksort-pivot? It passed Jenkins tests and I could not imagine why it failed on yours.
Hash table has its own cost. We'd better get quicksort right and see how it performs before rewriting code.
--Junchao Zhang
On Tue, Jul 2, 2019 at 2:37 PM Fande Kong <fdkong.jd at gmail.com<mailto:fdkong.jd at gmail.com>> wrote:
YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation fault: 11 (signal 11)
Segmentation fault :-)
As Jed said, it might be a good idea to rewrite the code using the hashing table.
Fande,
On Tue, Jul 2, 2019 at 1:27 PM Zhang, Junchao <jczhang at mcs.anl.gov<mailto:jczhang at mcs.anl.gov>> wrote:
Try this to see if it helps:
diff --git a/src/sys/utils/sorti.c b/src/sys/utils/sorti.c
index 1b07205a..90779891 100644
--- a/src/sys/utils/sorti.c
+++ b/src/sys/utils/sorti.c
@@ -294,7 +294,8 @@ static PetscErrorCode PetscSortIntWithArrayPair_Private(PetscInt *L,PetscInt *J,
- SWAP3(L[0],L[right/2],J[0],J[right/2],K[0],K[right/2],tmp);
+ i = MEDIAN(L,right);
+ SWAP3(L[0],L[i],J[0],J[i],K[0],K[i],tmp);
vl = L[0];
last = 0;
for (i=1; i<=right; i++) {
On Tue, Jul 2, 2019 at 12:14 PM Fande Kong via petsc-dev <petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov>> wrote:
BTW,
PetscSortIntWithArrayPair is used in MatStashSortCompress_Private.
Any way to avoid to use PetscSortIntWithArrayPair in MatStashSortCompress_Private?
Fande,
On Tue, Jul 2, 2019 at 11:09 AM Fande Kong <fdkong.jd at gmail.com<mailto:fdkong.jd at gmail.com>> wrote:
Hi Developers,
John just noticed that the matrix assembly was slow when having sufficient amount of off-diagonal entries. It was not a MPI issue since I was able to reproduce the issue using two cores on my desktop, that is, "mpirun -n 2".
I turned on a profiling, and 99.99% of the time was spent on PetscSortIntWithArrayPair (recursively calling). It took THREE MINUTES to get the assembly done. And then changed to use the option "-matstash_legacy" to restore
the code to the old assembly routine, and the same code took ONE SECOND to get the matrix assembly done.
Should write any better sorting algorithms?
Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190708/08278e77/attachment-0001.html>
