[petsc-dev] Slowness of PetscSortIntWithArrayPair in MatAssembly
Fande Kong fdkong.jd at gmail.com
Wed Jul 3 17:15:28 CDT 2019
Thanks Junchao,
But there is still segment fault. I guess you could write
some continuous integers to test your changes.
Fande
On Wed, Jul 3, 2019 at 12:57 PM Zhang, Junchao <jczhang at mcs.anl.gov> wrote:
> Fande and John,
>   Could you try jczhang/feature-better-quicksort-pivot? It passed Jenkins
> tests and I could not imagine why it failed on yours.
>   Hash table has its own cost. We'd better get quicksort right and see how
> it performs before rewriting code.
> --Junchao Zhang
> On Tue, Jul 2, 2019 at 2:37 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>> YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation fault: 11
>> (signal 11)
>> Segmentation fault :-)
>> As Jed said, it might be a good idea to rewrite the code using the
>> hashing table.
>> Fande,
>> On Tue, Jul 2, 2019 at 1:27 PM Zhang, Junchao <jczhang at mcs.anl.gov>
>> wrote:
>>> Try this to see if it helps:
>>> diff --git a/src/sys/utils/sorti.c b/src/sys/utils/sorti.c
>>> index 1b07205a..90779891 100644
>>> --- a/src/sys/utils/sorti.c
>>> +++ b/src/sys/utils/sorti.c
>>> @@ -294,7 +294,8 @@ static PetscErrorCode
>>> PetscSortIntWithArrayPair_Private(PetscInt *L,PetscInt *J,
>>>      PetscFunctionReturn(0);
>>> -  SWAP3(L[0],L[right/2],J[0],J[right/2],K[0],K[right/2],tmp);
>>> +  i = MEDIAN(L,right);
>>> +  SWAP3(L[0],L[i],J[0],J[i],K[0],K[i],tmp);
>>>    vl   = L[0];
>>>    last = 0;
>>>    for (i=1; i<=right; i++) {
>>> On Tue, Jul 2, 2019 at 12:14 PM Fande Kong via petsc-dev <
>>> petsc-dev at mcs.anl.gov> wrote:
>>>> BTW,
>>>> PetscSortIntWithArrayPair is used in MatStashSortCompress_Private.
>>>> Any way to avoid to use PetscSortIntWithArrayPair in
>>>> MatStashSortCompress_Private?
>>>> Fande,
>>>> On Tue, Jul 2, 2019 at 11:09 AM Fande Kong <fdkong.jd at gmail.com> wrote:
>>>>> Hi Developers,
>>>>> John just noticed that the matrix assembly was slow when having
>>>>> sufficient amount of off-diagonal entries. It was not a MPI issue since I
>>>>> was  able to reproduce the issue using two cores on my desktop, that is,
>>>>> "mpirun -n 2".
>>>>> I turned  on a profiling, and 99.99% of the time was spent
>>>>> on PetscSortIntWithArrayPair (recursively calling).   It took THREE MINUTES
>>>>>  to get the assembly done. And then changed to use the option
>>>>> "-matstash_legacy" to restore
>>>>> the code to the old assembly routine, and the same code took ONE
>>>>> SECOND to get the matrix assembly done.
>>>>> Should write any better sorting algorithms?
>>>>> Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190703/0663b8e2/attachment.html>
