[petsc-dev] Slowness of PetscSortIntWithArrayPair in MatAssembly
    Zhang, Junchao
    jczhang at mcs.anl.gov
    Tue Jul  2 13:23:42 CDT 2019
Is it because the array is already sorted?
--Junchao Zhang
On Tue, Jul 2, 2019 at 12:13 PM Fande Kong via petsc-dev <petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov>> wrote:
Hi Developers,
John just noticed that the matrix assembly was slow when having sufficient amount of off-diagonal entries. It was not a MPI issue since I was  able to reproduce the issue using two cores on my desktop, that is, "mpirun -n 2".
I turned  on a profiling, and 99.99% of the time was spent on PetscSortIntWithArrayPair (recursively calling).   It took THREE MINUTES  to get the assembly done. And then changed to use the option "-matstash_legacy" to restore
the code to the old assembly routine, and the same code took ONE SECOND to get the matrix assembly done.
Should write any better sorting algorithms?
Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190702/6e364fb5/attachment.html>
