[petsc-dev] HYPRE_LinSysCore.h
    Stefano Zampini
    stefano.zampini at gmail.com
    Tue Jan 29 16:18:34 CST 2019
Or use
--download-hypre-configure-arguments=--with-fei
Il giorno mer 30 gen 2019 alle ore 00:58 Balay, Satish via petsc-dev <
petsc-dev at mcs.anl.gov> ha scritto:
> On Tue, 29 Jan 2019, Victor Eijkhout via petsc-dev wrote:
> > I’ve been happily freeloading on the petsc installation in the sense
> that I claim to install things like hypre on our clusters by pointing into
> the petsc installation.
> > Until of course someone needs a bit that does not get installed by petsc.
> > In this case: HYPRE_LinSysCore.h
> > Does the petsc hypre installation pick and choose what parts of hypre to
> install? Can I exert some influence on this?
> You can get this file with:
> diff --git a/config/BuildSystem/config/packages/hypre.py
> b/config/BuildSystem/config/packages/hypre.py
> index 620e51602a..c3cbd55877 100644
> --- a/config/BuildSystem/config/packages/hypre.py
> +++ b/config/BuildSystem/config/packages/hypre.py
> @@ -68,7 +68,7 @@ class Configure(config.package.GNUPackage):
>      args.append('--with-fmangle-lapack='+mang)
>      args.append('--without-mli')
> -    args.append('--without-fei')
> +    #args.append('--without-fei')
>      args.append('--without-superlu')
>      if self.getDefaultIndexSize() == 64:
>        args.append('--enable-bigint')
> I don't remember why these hypre modules are disabled by default. They
> must have caused grief at some point.
> Satish
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190130/331c1057/attachment.html>
