[petsc-dev] How to add root values to leaves in PetscSF?
Jed Brown
jed at jedbrown.org
Tue Jan 22 16:07:55 CST 2019
It is not supported at this time. What does your use case look like?
Do roots have degree greater than 1?
"Zhang, Junchao via petsc-dev" <petsc-dev at mcs.anl.gov> writes:
> On Tue, Jan 22, 2019 at 1:35 PM Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
> On Tue, Jan 22, 2019 at 2:23 PM Zhang, Junchao via petsc-dev <petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov>> wrote:
> I want to add root values to leaves, and keep root unchanged. PetscSFBcast came to my mind, but unfortunately it only broadcasts roots and does not have an MPI_Op argument like PetscSFReduce for me to choose from INSERT_VALUES, ADD_VALUES, etc.
> Any tips? Thanks.
> PS: I met this problem when I tried to implement VecScatter in SF. In VecScatter, multiple entries of vec x can be scattered to the same entry of vec y, and one entry of x can also be scattered to multiple entries of y. I want to use one SF for all combinations of SCATTER_FORWARD/BACKWARD, INSERT/ADD_VALUES. It seems impossible with current SF interface.
> I think you might want this: https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PetscSF/PetscSFFetchAndOpBegin.html
> I read it as: Leaves are accumulated to root (root is changed), and leaves get a snapshot of the root before each atomic update. It is not what I want.
> Thanks,
> Matt
> --Junchao Zhang
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
