[petsc-dev] Segmentation faults in MatMatMult & MatTransposeMatMult
    Jed Brown
    jed at jedbrown.org
    Wed Jan 16 08:22:32 CST 2019
Matthew Knepley <knepley at gmail.com> writes:
> On Wed, Jan 16, 2019 at 9:01 AM Jed Brown via petsc-dev <
> petsc-dev at mcs.anl.gov> wrote:
>> Pierre Jolivet via petsc-dev <petsc-dev at mcs.anl.gov> writes:
>> > OK, I was wrong about MATAIJ, as Jed already pointed out.
>> > What about BAIJ or Dense matrices?
>> BAIJ (and SBAIJ) is handled by MatXAIJSetPreallocation.
> Dense matrices don't need preallocation.
True, MatMPIDenseSetPreallocation is more like a *PlaceArray or
Create*WithArray.  The caller needs to be aware of parallelism to create
and use arrays; I guess Pierre does that but doesn't want the noise at
the particular call site (though at least the if statements aren't
needed).
