[petsc-dev] Segmentation faults in MatMatMult & MatTransposeMatMult
Pierre Jolivet
pierre.jolivet at enseeiht.fr
Mon Jan 14 23:17:54 CST 2019
Cf. the end of my sentence: "(I know, I could switch to SeqAIJ_SeqDense, but that is not an option I have right now)”
All my Mat are of type MATMPIX. Switching to MATX here as you suggested would mean that I need to add a bunch of if(comm_size == 1) MatSeqXSetPreallocation else MatMPIXSetPreallocation in the rest of my code, which is something I would rather avoid.
Pierre
> On 14 Jan 2019, at 10:30 PM, Zhang, Hong <hzhang at mcs.anl.gov> wrote:
> Replace
> ierr = MatSetType(A, MATMPIAIJ);CHKERRQ(ierr);
> to
> ierr = MatSetType(A, MATAIJ);CHKERRQ(ierr);
> Replace
> ierr = MatSetType(B, MATMPIDENSE)i;CHKERRQ(ierr);
> to
> ierr = MatSetType(B, MATDENSE)i;CHKERRQ(ierr);
> Then add
> MatSeqAIJSetPreallocation()
> MatSeqDenseSetPreallocation()
> Hong
> On Mon, Jan 14, 2019 at 2:51 PM Pierre Jolivet via petsc-dev <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>> wrote:
> Hello,
> Is there any chance to get MatMatMult_MPIAIJ_MPIDense and MatTransposeMatMult_MPIAIJ_MPIDense fixed so that the attached program could run _with a single_ process? (I know, I could switch to SeqAIJ_SeqDense, but that is not an option I have right now)
> Thanks in advance,
> Pierre
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190115/c01c6b6e/attachment.html>
