[petsc-dev] git script for finding "outdated" branches in next
    Matthew Knepley
    knepley at gmail.com
    Sat Jan 12 12:55:18 CST 2019
On Fri, Jan 11, 2019 at 6:14 PM Balay, Satish via petsc-dev <
petsc-dev at mcs.anl.gov> wrote:
> Currently I see:
> balay at sb /home/balay/petsc (master=)
> $ gitreadytomerge
>   origin/balay/metis-add-doubleprecision-option/maint
>   origin/barry/feature-dmda1d-periodic-fill
>   origin/Fande-Kong/fixed_hierarchical_partitioning_weights_master
>   origin/haplav/feature-hdf5-improve-attribute-io
>   origin/hzhang/fix-submats-memleak/maint
>   origin/maint
>   origin/next
>   origin/psanan/dmstag-ex4-fix
>   origin/rmills/fix-ex12-runtype-option/maint
> $ gitreadytomergeincomplete
>   origin/knepley/fix-plex-interpolation-parallel
>   origin/next
> So the extra branch in 'incomplete' list is
> But then - next has:
> commit 216eaf983554edc1ad429265718576c68c47b72c
> Author: Karl Rupp <me at karlrupp.net>
> Date:   Wed Oct 3 07:19:27 2018 +0200
>     Revert "Merge branch 'knepley/fix-plex-interpolation-parallel' into
> next [PR #1130]"
>     This reverts commit 626808e7b5e6d32fe8ac4d345872231b9c5782ff, reversing
>     changes made to 02a379f6432ba4e531280ac582edfd94c6a600ec.
> So I'll ignore this branch.. I also see 'declined' on the PR.
> https://bitbucket.org/petsc/petsc/pull-requests/1130/knepley-fix-plex-interpolation-parallel/diff
Yep, this needs a fix that I have to figure out. I should have time before
the semester starts.
    Matt
> Satish
> On Fri, 11 Jan 2019, Balay, Satish via petsc-dev wrote:
> > I use the following:
> > alias gitreadytomerge'=git fetch -p && comm -12 <(git branch -r --merged
> origin/next | sort) <(git branch -r --no-merged origin/master | sort)'
> > alias gitreadytomergesorted='git fetch && paste <(gitreadytomerge |
> xargs git show -q --format=format:%aI) <(gitreadytomerge) |sort -n'
> > alias gitreadytomergeincomplete='git fetch -p && (for i in $(git log
> origin/master..origin/next --no-merges --format=%H); do git branch -r
> --contains $i; done | sort | uniq)'
> > The last one can take a while to process all the commits in next.
> > Note: they have some corner cases - like listing branches added to next
> > - and subsequently removed. [or if branch-A is merged to branch-B
> > and branch-B is merged to next - then branch-A is also listed etc..]
> > Satish
> > On Fri, 11 Jan 2019, Smith, Barry F. via petsc-dev wrote:
> > >    Jed gave me this git script to find branches in next that have not
> yet been merged to master
> > > alias gitmasternotupdated="comm -12 <(git branch -r --merged
> origin/next | grep origin/ | sort) <(git branch -r --no-merged
> origin/master ) | xargs -n1 git log -1 --format='%Cgreen%ci
> %C(yellow)%d%Creset %s' --abbrev-commit |  sed 's?origin/[a-z/-]*, ??g' |
> grep -v '(origin/next)' | cut -b 1-`stty size | cut -d" " -f 2` | sort -u |
> grep -v Merge"
> > > Unfortunately it does not list branches in next that have had
> additional commits added to them (by someone fixing problems seen in
> nightly tests) since they were merged to next. Hence they can be "lost"
> branches that we forget to merge into next again for another round of
> testing.
> > >    Could someone cook up a script that captures these branches? That
> is, it shows branches in next that are not master but have been updated
> since they were merged into next.
> > >    Thanks
> > >     Barry
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190112/0f0f1735/attachment.html>
