[petsc-dev] PETSc blame digest (next) 2019-01-11
    Fande Kong
    fdkong.jd at gmail.com
    Fri Jan 11 10:13:09 CST 2019
Hi Karl,
Could you merge my patch into next? So that we do not receive these
complaints any more.
Fande Kong,
On Fri, Jan 11, 2019 at 6:28 AM PETSc checkBuilds <
petsc-checkbuilds at mcs.anl.gov> wrote:
> Dear PETSc developer,
> This email contains listings of contributions attributed to you by
> `git blame` that caused compiler errors or warnings in PETSc automated
> testing.  Follow the links to see the full log files. Please attempt to fix
> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are
> unable
> to resolve the issues.
> Thanks,
>   The PETSc development team
> warnings attributed to commit
> https://bitbucket.org/petsc/petsc/commits/6c04a3c
> Create an API ISCreateSubIS that extracts
>   src/vec/is/is/interface/index.c:216
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-linux-opt-cxx-quad_grind.log
>       /sandbox/petsc/petsc.next-3/src/vec/is/is/interface/index.c:216:27:
> warning: 'owner' may be used uninitialized in this function
> [-Wmaybe-uninitialized]
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-linux-opt-misc_el6.log
> /home/sandbox/petsc/petsc.next/src/vec/is/is/interface/index.c:216:20:
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-linux-pkgs-opt_crank.log
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-freebsd-cxx-pkgs-opt_wii.log
>       /usr/home/balay/petsc.next-2/src/vec/is/is/interface/index.c:216:20:
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-linux-IPL64_thrash.log
>       /sandbox/petsc/petsc.next-2/src/vec/is/is/interface/index.c:216:20:
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-freebsd-pkgs-opt_wii.log
>       /usr/home/balay/petsc.next-3/src/vec/is/is/interface/index.c:216:20:
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-cuda-single_es.log
>       /sandbox/petsc/petsc.next-3/src/vec/is/is/interface/index.c:216:20:
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-linux-gcc-cxx-avx2_knl.log
>       /home/petsc/petsc.next-3/src/vec/is/is/interface/index.c:216:20:
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-linux-pkgs-gcov_cg.log
>   src/vec/is/is/interface/index.c:217
>       /usr/home/balay/petsc.next-3/src/vec/is/is/interface/index.c:217:21:
> warning: 'lidx' may be used uninitialized in this function
>       /sandbox/petsc/petsc.next-3/src/vec/is/is/interface/index.c:217:27:
>       /sandbox/petsc/petsc.next-3/src/vec/is/is/interface/index.c:217:21:
>       /sandbox/petsc/petsc.next-2/src/vec/is/is/interface/index.c:217:21:
> /home/sandbox/petsc/petsc.next/src/vec/is/is/interface/index.c:217:21:
>       /home/petsc/petsc.next-3/src/vec/is/is/interface/index.c:217:21:
>       /usr/home/balay/petsc.next-2/src/vec/is/is/interface/index.c:217:21:
> To opt-out from receiving these messages - send a request to
> petsc-dev at mcs.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190111/38a08444/attachment.html>
