[petsc-dev] Regression in Vec assembly
    Stefano Zampini
    stefano.zampini at gmail.com
    Tue Feb 19 09:24:14 CST 2019
Jed,
I’m resurrecting this thread since I believe this bug has not yet been fixed.
I have spent a couple of hours today tracking down a bug in my code, that I finally confined to be related with VecSetValuesBlocked.
I have pushed an example that shows the problem here https://bitbucket.org/petsc/petsc/commits/1cb7fb90b416ce1d4e4767a0d5a2ef5043656d53?at=stefano_zampini/feature-pcbddc-enablelor <https://bitbucket.org/petsc/petsc/commits/1cb7fb90b416ce1d4e4767a0d5a2ef5043656d53?at=stefano_zampini/feature-pcbddc-enablelor>
Could you please have a look?
Stefano
> On Apr 24, 2016, at 10:52 PM, Jed Brown <jed at jedbrown.org> wrote:
> Lisandro Dalcin <dalcinl at gmail.com> writes:
>> Do you remember about this regression? My PetIGA tests are still
>> failing with petsc/master.
> Yes, I have most of a fix in a branch that I'm working to finish.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190219/6c77061a/attachment.html>
