[petsc-dev] Errors from PETSc 3.11 and 3.12 headers
Balay, Satish
balay at mcs.anl.gov
Sun Dec 22 15:56:47 CST 2019
Ok - you'll have to somehow make sure the same version of gcc gets used when building petsc4py
Since petsc4py is using mpicc - I think you just need to make sure the correct gcc is in PATH.
Perhaps Lisandro can correct me [if there a more suitable way of specifying the correct gcc to python distutils via mpicc]
Satish
On Sun, 22 Dec 2019, Antonio Trande wrote:
> On 22/12/19 21:07, Balay, Satish wrote:
> > [petsc at petsc-c7 petsc:maint-3.11]$ gcc --version
> > gcc (GCC) 4.8.5 20150623 (Red Hat 4.8.5-39)
> I'm using GCC from devtools-8 packages (GCC-8.3.1)
> > On CentOS-7 I get:
> > [petsc at petsc-c7 petsc:maint-3.11]$ grep PETSC_DEPRECATED_ENUM arch-linux2-c-debug/include/petscconf.h
> > #ifndef PETSC_DEPRECATED_ENUM
> > #define PETSC_DEPRECATED_ENUM(why)
> > However - you have [in petscconf.h provided]:
> > #define PETSC_DEPRECATED(why) __attribute((deprecated))
> > #endif
> > Is PETSc built with a different version of compiler? configure.log will have the details.
> Attached 2 logs of Configure: with and without MPI activated.
