[petsc-dev] Errors from PETSc 3.11 and 3.12 headers
    Antonio Trande
    anto.trande at gmail.com
    Sun Dec 22 13:39:56 CST 2019
On 22/12/19 20:32, Antonio Trande wrote:
> On 22/12/19 20:15, Balay, Satish wrote:
>> This error is strange. The issue does not come up in petsc build - but in petsc4py build.
>> I see the petsc4py build is with:
>> + CFLAGS=' -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches   -m64 -mtune=generic'
>> mpicc -pthread -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -O3 -fPIC -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -fPIC -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -DPETSC_DIR=/usr -I/usr/include/openmpi-x86_64 -I/usr/include/openmpi-x86_64/hypre -I/usr/lib64/gfortran/modules/openmpi/petsc -I/usr/include/openmpi-x86_64/petsc -I/usr/include -Isrc/include -I/usr/lib64/python3.6/site-packages/numpy/core/include -I/usr/include/python3.6m -c src/PETSc.c -o build/temp.linux-x86_64-3.6/src/PETSc.o
>> I've attempted a petsc+petsc4py build using both the following on fedora-31 [with petsc-3.12/maint] - and there were no errors
> Yes, it does not happen on Fedora. That error appears on CentOS-7
> machines only, both with Python2 and Python3.
> petscconf.h is attached
Antonio Trande
Fedora Project
mailto 'sagitter at fedoraproject dot org'
GPG key: 0x7B30EE04E576AA84
GPG key server: https://keys.openpgp.org/
Type: text/x-chdr
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20191222/806a7226/attachment-0001.bin>
