[petsc-dev] Errors from PETSc 3.11 and 3.12 headers
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Sun Dec 22 12:49:07 CST 2019
  Please send configure.log and /usr/include/openmpi-x86_64/petsc/petscconf.h
  In theory our configure checks if deprecated can be used for Enums but perhaps our test is not complete.
   Barry
> On Dec 22, 2019, at 12:01 PM, Antonio Trande <anto.trande at gmail.com> wrote:
> Hi all.
> I don't know of these are errors related to petsc4py or to PETSc, i'm
> writing a mail to this mailing list too.
> Issue reported to petsc4py folks:
> https://bitbucket.org/petsc/petsc4py/issues/133/compiling-petsc4py-3110-against-petsc-3113
> In file included from /usr/include/openmpi-x86_64/petsc/petscsys.h:14:0,
>                 from /usr/include/openmpi-x86_64/petsc/petscbag.h:4,
>                 from /usr/include/openmpi-x86_64/petsc/petsc.h:5,
>                 from src/petsc4py.PETSc.c:591,
>                 from src/PETSc.c:4:
> /usr/include/openmpi-x86_64/petsc/petscconf.h:85:36: error: expected ','
> or '}' before '__attribute'
> #define PETSC_DEPRECATED_ENUM(why) __attribute((deprecated))
> /usr/include/openmpi-x86_64/petsc/petscksp.h:430:76: note: in expansion
> of macro 'PETSC_DEPRECATED_ENUM'
> #define KSP_DIVERGED_PCSETUP_FAILED_DEPRECATED
> KSP_DIVERGED_PCSETUP_FAILED PETSC_DEPRECATED_ENUM("Use
> KSP_DIVERGED_PC_FAILED (since v3.11)")
> /usr/include/openmpi-x86_64/petsc/petscksp.h:452:15: note: in expansion
> of macro 'KSP_DIVERGED_PCSETUP_FAILED_DEPRECATED'
>               KSP_DIVERGED_PCSETUP_FAILED_DEPRECATED  = -11,
> In file included from src/PETSc.c:4:0:
> src/petsc4py.PETSc.c: In function '__pyx_f_8petsc4py_5PETSc_KSP_Converged':
> src/petsc4py.PETSc.c:35723:22: error: 'KSP_CONVERGED_ITERATING'
> undeclared (first use in this function)
>     (__pyx_v_r[0]) = KSP_CONVERGED_ITERATING;
> src/petsc4py.PETSc.c:35723:22: note: each undeclared identifier is
> reported only once for each function it appears in
> '__pyx_pf_8petsc4py_5PETSc_3KSP_50callConvergenceTest':
> src/petsc4py.PETSc.c:171473:20: error: 'KSP_CONVERGED_ITERATING'
>   __pyx_v_reason = KSP_CONVERGED_ITERATING;
> '__pyx_pf_8petsc4py_5PETSc_3KSP_112getConvergedReason':
> src/petsc4py.PETSc.c:174687:20: error: 'KSP_CONVERGED_ITERATING'
> src/petsc4py.PETSc.c: In function '__pyx_pymod_exec_PETSc':
> src/petsc4py.PETSc.c:303605:51: error: 'KSP_CONVERGED_ITERATING'
>   __pyx_t_7 =
> __Pyx_PyInt_From_KSPConvergedReason(KSP_CONVERGED_ITERATING); if
> (unlikely(!__pyx_t_7)) __PYX_ERR(37, 64, __pyx_L1_error)
> error: command 'mpicc' failed with exit status
> Antonio Trande
> Fedora Project
> mailto 'sagitter at fedoraproject dot org'
> GPG key: 0x7B30EE04E576AA84
> GPG key server: https://keys.openpgp.org/
