[petsc-dev] CI update: valgrind test mandatory
    Balay, Satish
    balay at mcs.anl.gov
    Tue Dec 17 10:31:52 CST 2019
All petsc Merge Request creators,
The issues with valgrind test are now fixed - so this test no longer
has 'allow_failure' flag set.
So its best to rebase all MRs over latest master [or maint - if
appropriate] - before submitting test pipelines - this way - we are
using the valgrind test results correctly [and not inadvertently
merging in MRs with valgrind test failures]
Satish
