[petsc-dev] error with --download-amgx
Fande Kong
fdkong.jd at gmail.com
Fri Dec 13 13:28:30 CST 2019
Thanks, Mark,
it looks really cool!
Fande,
On Fri, Dec 13, 2019 at 11:29 AM Mark Adams <mfadams at lbl.gov> wrote:
> There is a MR winding its way in. I think it is ready to go. There is
> confusion with branches but it is something like
> barry/12-01-19-pc-feature-amgx.
> It is a PC, but it is so fragile. I could only get AMGx to work with
> classical AMG (preferred) by using its Krylov solver also. So the test sets
> -ksp_preonly.
> There is an example in snes/ex13.
> On Fri, Dec 13, 2019 at 12:09 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>> I was wondering how we use AMGx? It is a PC? Do we have a native
>> interface to this package? Any example?
>> Fande,
>> On Tue, Dec 3, 2019 at 9:10 PM Smith, Barry F. <bsmith at mcs.anl.gov>
>> wrote:
>>> Ok, since we are using a fork of the repository if it is causing grief
>>> we can remove it but otherwise best just to leave it since it put in by the
>>> AMGX developers.
>>> > On Dec 3, 2019, at 10:00 PM, Balay, Satish <balay at mcs.anl.gov> wrote:
>>> > Its from the attached configure.log [from a prior e-mail on this
>>> > thread] - and this flag is not passed in from petsc configure to amgx
>>> > cmake - so it must be somehow set internally in this package.
>>> > Satish
>>> > On Wed, 4 Dec 2019, Smith, Barry F. wrote:
>>> >>> Also - its best to avoid -Werror in externalpackage builds..
>>> >> Hmm, my branch uses the CMake package to do the install (it has no
>>> custom code) so is this a bug in package.py that it doesn't strip out the
>>> -Werror when passing stuff to cmake?
>>> >> There is not enough information your email for me to determine where
>>> this message you printed below came from. Did it come from my branch?
>>> >> Barry
>>> >>> On Dec 3, 2019, at 9:29 PM, Balay, Satish <balay at mcs.anl.gov> wrote:
>>> autofs/nccs-svm1_sw/summit/.swci/0-core/opt/spack/20180914/linux-rhel7-ppc64le/gcc-4.8.5/cmake-3.15.2-xit2o3iepxvqbyku77lwcugufilztu7t/bin/cmake
>>> -E remove
>>> /autofs/nccs-svm1_home1/adams/petsc/arch-summit-opt64-gnu-cuda/externalpackages/git.amgx/petsc-build/core/CMakeFiles/amgx_core.dir/src/classical/interpolators/./
>>> amgx_core_generated_common.cu.o
>>> >>> /sw/summit/cuda/10.1.168/bin/nvcc -M -D__CUDACC__
>>> plugin_config.cu -o
>>> /autofs/nccs-svm1_home1/adams/petsc/arch-summit-opt64-gnu-cuda/externalpackages/git.amgx/petsc-build/base/CMakeFiles/amgx_base.dir/__/amgx_base_generated_plugin_config.cu.o.NVCC-depend
>>> -m64 -Xcompiler
>>> ,\"-fstack-protector\",\"-g\",\"-O2\",\"-fPIC\",\"-Wno-terminate\",\"-static-libgcc\",\"-fopenmp\",\"-DRAPIDJSON_DEFINED\",\"-DAMGX_WITH_MPI\",\"-fstack-protector\",\"-g\",\"-O2\",\"-fPIC\"
>>> -ccbin mpicxx -gencode=arch=compute_35,code=\"sm_35,compute_35\"
>>> -gencode=arch=compute_52,code=\"sm_52,compute_52\"
>>> -gencode=arch=compute_60,code=\"sm_60,compute_60\"
>>> -gencode=arch=compute_70,code=\"sm_70,compute_70\" -O3 -DNDEBUG -std=c++11
>>> --Werror cross-execution-space-call -DNVCC
>>> -I/autofs/nccs-svm1_home1/adams/petsc/arch-summit-opt64-gnu-cuda/externalpackages/git.amgx/../../thrust
>>> -I/autofs/nccs-svm1_home1/adams/petsc/arch-summit-opt64-gnu-cuda/externalpackages/git..amgx/base/include
>>> -I/sw/summit/cuda/10.1.168/include
>>> -I/autofs/nccs-svm1_home1/adams/petsc/arch-summit-opt64-gnu-cuda/externalpackages/git.amgx/external/rapidjson/include
>>> >>> -- Removing
>>> /autofs/nccs-svm1_home1/adams/petsc/arch-summit-opt64-gnu-cuda/externalpackages/git.amgx/petsc-build/base/CMakeFiles/amgx_base.dir/src/./amgx_base_generated_device_properties.cu.o
>>> >>> Satish
>>> >>> On Tue, 3 Dec 2019, Mark Adams wrote:
>>> >>>> Barry,
>>> >>>> First, there is a fix that we need in the AMGx repo (appended).
>>> >>>> I've never had problems like this not being able to build. I will
>>> try to
>>> >>>> build my AMGx manually to check.
>>> >>>> 21:31 master *= ~/AMGX$ git diff
>>> >>>> diff --git a/base/include/amgx_c_wrappers.inl
>>> >>>> b/base/include/amgx_c_wrappers.inl
>>> >>>> index 42496f0..ed9f0e1 100644
>>> >>>> --- a/base/include/amgx_c_wrappers.inl
>>> >>>> +++ b/base/include/amgx_c_wrappers.inl
>>> >>>> @@ -643,7 +643,7 @@ inline AMGX_Mode get_mode_from(const Envelope
>>> &envl)
>>> >>>> //throws...
>>> >>>> - FatalError("Mode not found.\n", AMGX_ERR_BAD_MODE);
>>> >>>> + // FatalError("Mode not found.\n", AMGX_ERR_BAD_MODE);
>>> >>>> AMGX_Mode mode = static_cast<AMGX_Mode>(itFound->second);
>>> >>>> @@ -1125,4 +1125,4 @@ inline bool
>>> remove_managed_matrix(AMGX_matrix_handle
>>> >>>> envl)
>>> >>>> } //namespace unnamed
>>> >>>> On Tue, Dec 3, 2019 at 8:50 PM Smith, Barry F. <bsmith at mcs.anl.gov>
>>> wrote:
>>> >>>>> The first error is
>>> >>>>> nvcc error : 'cicc' died due to signal 9 (Kill signal)
>>> >>>>> later
>>> /autofs/nccs-svm1_home1/adams/petsc/arch-summit-opt64-gnu-cuda/externalpackages/git.amgx/base/src/
>>> >>>>> amgx_c_common.cu(77): catastrophic error: error while writing
>>> generated
>>> >>>>> C++ file: Cannot allocate memory
>>> >>>>> 1 catastrophic error detected in the compilation of
>>> >>>>> "/tmp/tmpxft_000038d3_00000000-4_amgx_c_common.cpp4.ii".
>>> >>>>> Whatever machine you are compiling on seems to be overloaded. What
>>> does
>>> >>>>> top show? Can you log into "different" compiler servers on Summit?
>>> >>>>> I run the install on the utk system with no problems like this.
>>> >>>>> PETSc configure is deciding
>>> >>>>> TEST configureMakeNP from
>>> config.packages.make(/autofs/nccs-svm1_home1/adams/petsc/config/BuildSystem/config/packages/make.py:168)
>>> >>>>> TESTING: configureMakeNP from
>>> config.packages.make(config/BuildSystem/config/packages/make.py:168)
>>> >>>>> check no of cores on the build machine [perhaps to do make '-j
>>> ncores']
>>> >>>>> module multiprocessing found 128 cores: using make_np = 59
>>> >>>>> Defined make macro "MAKE_NP" to "59"
>>> >>>>> Defined make macro "MAKE_TEST_NP" to "49"
>>> >>>>> Defined make macro "MAKE_LOAD" to "166.4"
>>> >>>>> Defined make macro "NPMAX" to "128"
>>> >>>>> then somehow this gets passed down to the AMGX cmake. Perhaps you
>>> could
>>> >>>>> try less greedy numbers.
>>> >>>>> Executing: /usr/bin/gmake -j59 -l166.4
>>> >>>>> Perhaps try
>>> >>>>> --with-make-np=20
>>> >>>>> --with-make-load=20
>>> >>>>> Barry
>>> >>>>>> On Dec 3, 2019, at 4:17 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>> >>>>>> That might have been from an old .nsf file. Here is a new one.
>>> I'm sure
>>> >>>>> I have the disk space.
>>> >>>>>> On Tue, Dec 3, 2019 at 4:51 PM Mark Adams <mfadams at lbl.gov>
>>> wrote:
>>> >>>>>> Humm, clean up and seem to have different error:
>>> >>>>>> On Tue, Dec 3, 2019 at 3:45 PM Matthew Knepley <knepley at gmail.com
>>> >>>>> wrote:
>>> >>>>>> Could you have run out of disk space?
>>> >>>>>> /usr/bin/ranlib: libamgx_base.a: Input/output error
>>> >>>>>> gmake[2]: *** [base/libamgx_base.a] Error 1
>>> >>>>>> gmake[2]: *** Deleting file `base/libamgx_base.a'
>>> >>>>>> gmake[1]: *** [base/CMakeFiles/amgx_base.dir/all] Error 2
>>> >>>>>> gmake: *** [all] Error 2
>>> >>>>>> Matt
>>> >>>>>> On Tue, Dec 3, 2019 at 1:44 PM Mark Adams <mfadams at lbl.gov>
>>> wrote:
>>> >>>>>> What most experimenters take for granted before they begin their
>>> >>>>> experiments is infinitely more interesting than any results to
>>> which their
>>> >>>>> experiments lead.
>>> >>>>>> -- Norbert Wiener
>>> >>>>>> https://www.cse.buffalo.edu/~knepley/
>>> >>>>>> <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20191213/1b73ab7d/attachment-0001.html>
