[petsc-dev] Valgrind problems
Matthew Knepley
knepley at gmail.com
Sat Dec 7 18:00:31 CST 2019
Nope, you are right.
Matt
On Sat, Dec 7, 2019 at 6:19 PM Balay, Satish <balay at mcs.anl.gov> wrote:
> The fix for this is in 363424266cb675e6465b4c7dcb06a6ff8acf57d2
> Do you have this commit in your branch - and still seeing issues?
> Satish
> On Sat, 7 Dec 2019, Patrick Sanan wrote:
> > I was actually wondering about this, as in some cases valgrind errors
> appear and sometimes they don't, but I didn't dig into it too deeply.
> > Here's my workaround, FWIW, which shows some output for that test on
> master.
> > I don't see any output when I just run the tests like this:
> > VALGRIND=1 make -f gmakefile.test test
> globsearch="dm_impls_plex_tests-ex1_fluent_2"
> > But I do see something if I do this to find any non-empty .err files:
> > find $PETSC_ARCH/tests -name *.err ! -size 0
> > And then I see these valgrind warnings after copy-pasting the path:
> > $ cat
> arch-master-extra-opt/tests/dm/impls/plex/examples/tests/runex1_fluent_2/runex1_fluent_2.err
> > ==4990== Conditional jump or move depends on uninitialised value(s)
> > ==4990== at 0x4C3705A: rawmemchr (in
> /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==4990== by 0x7687351: _IO_str_init_static_internal (strops.c:41)
> > ==4990== by 0x767878C: vsscanf (iovsscanf.c:40)
> > ==4990== by 0x76721A3: sscanf (sscanf.c:32)
> > ==4990== by 0x588147D: DMPlexCreateFluent_ReadSection
> (plexfluent.c:105)
> > ==4990== by 0x5882E3A: DMPlexCreateFluent (plexfluent.c:246)
> > ==4990== by 0x588492F: DMPlexCreateFluentFromFile (plexfluent.c:30)
> > ==4990== by 0x577E2B7: DMPlexCreateFromFile (plexcreate.c:3254)
> > ==4990== by 0x10BEDF: CreateMesh (ex1.c:170)
> > ==4990== by 0x10A20B: main (ex1.c:430)
> > ==4990== Uninitialised value was created by a stack allocation
> > ==4990== at 0x5881313: DMPlexCreateFluent_ReadSection
> (plexfluent.c:96)
> > ==4990==
> > ==4990== Use of uninitialised value of size 8
> > ==4990== at 0x766276F: _IO_vfscanf (vfscanf.c:633)
> > ==4990== by 0x767879C: vsscanf (iovsscanf.c:41)
> (plexfluent.c:105)
> (plexfluent.c:96)
> > ==4990==
> > ==4990== at 0x766277B: _IO_vfscanf (vfscanf.c:630)
> (plexfluent.c:105)
> (plexfluent.c:96)
> > ==4990==
> > > Am 07.12.2019 um 21:45 schrieb Matthew Knepley <knepley at gmail.com>:
> > > I am trying to clean up valgrind errors. However this one
> > > is valgrind clean on my machine. Does anyone get it to output
> something?
> > > Thanks,
> > > Matt
> > > What most experimenters take for granted before they begin their
> experiments lead.
> > > -- Norbert Wiener
> > > https://www.cse.buffalo.edu/~knepley/ <
> http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20191207/df66df81/attachment.html>
