[petsc-dev] petsc-dev post from tabrezali at gmail.com requires approval
Matthew Knepley
knepley at gmail.com
Tue Aug 27 03:27:42 CDT 2019
On Tue, Aug 27, 2019 at 4:11 AM Lisandro Dalcin <dalcinl at gmail.com> wrote:
> On Mon, 26 Aug 2019 at 21:26, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>> > On Aug 26, 2019, at 10:11 AM, Lisandro Dalcin <dalcinl at gmail.com>
>> wrote:
>> > On Sun, 25 Aug 2019 at 18:37, Smith, Barry F. via petsc-dev <
>> petsc-dev at mcs.anl.gov> wrote:
>> > Metis is installed.
>> > config/PETSc/Configure.py:
>> self.addDefine('HAVE_'+i.PACKAGE.replace('-','_'), 1) # ONLY list package
>> if it is used directly by PETSc (and not only by another package)
>> > Since metis is not used by PETSc we don't set the PETSC_HAVE_METIS
>> flag because PETSc doesn't need it.
>> > This is not true, in DMPlex we have an explicit call to
>> METIS_PartGraphKway(). Of course, this code is protected with just
>> HAVE_PARMETIS, because if you have parmetis, then you have metis.
>> Hmm, I think is should be protected with HAVE_METIS. There is nothing
>> that says PETSc can only be built with metis plus parmetis; it could be
>> built with just metis.
> Sorry, maybe I was not clear enough.
> The DMPlex code I'm talkinga about uses both ParMETIS and METIS, depending
> on the input graph being sequential or parallel.
> https://gitlab.com/petsc/petsc/blob/master/src/dm/impls/plex/plexpartition.c#L1799
> So this code requires ParMETIS, and if you have it, then you have METIS,
> the a HAVE_METIS check seems a bit redundant to me.
> Do you still think we should change it?
> Or maybe we should use `#if defined(PETSC_HAVE_METIS) &&
> defined(PETSC_HAVE_PARMETIS)`?
> Anything to add, Matthew?
1) I think we turn on PETSC_HAVE_METIS
2) I think we leave the guard as PARMETIS since we need it for the parallel
case and it implies Metis
Matt
> PS: In any case, I think configure should emit PETSC_HAVE_METIS, we are
> really using it.
> Lisandro Dalcin
> Research Scientist
> Extreme Computing Research Center (ECRC)
> King Abdullah University of Science and Technology (KAUST)
> http://ecrc.kaust.edu.sa/
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190827/617759e2/attachment.html>
