[petsc-dev] petsc-dev post from tabrezali at gmail.com requires approval
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Sun Aug 25 10:37:13 CDT 2019
   Metis is installed.
config/PETSc/Configure.py:        self.addDefine('HAVE_'+i.PACKAGE.replace('-','_'), 1)  # ONLY list package if it is used directly by PETSc (and not only by another package)
    Since metis is not used by PETSc we don't set the PETSC_HAVE_METIS flag because PETSc doesn't need it.
   Barry
> On Aug 25, 2019, at 7:55 AM, petsc-dev-owner at mcs.anl.gov wrote:
> As list administrator, your authorization is requested for the
> following mailing list posting:
>    List:    petsc-dev at mcs.anl.gov
>    From:    tabrezali at gmail.com
>    Subject: PETSC_HAVE_METIS
>    Reason:  Post by non-member to a members-only list
> At your convenience, visit:
>    https://lists.mcs.anl.gov/mailman/admindb/petsc-dev
> to approve or deny the request.
> From: Tabrez Ali <tabrezali at gmail.com>
> Date: August 25, 2019 at 7:53:49 AM CDT
> To: <petsc-dev at mcs.anl.gov>
> Reply-To: <tabrezali at gmail.com>
> Hello
> I recently configured/built PETSc (latest) with the '--download-metis' option. However, PETSC_HAVE_METIS doesn't appear to be defined.
> Any ideas, as to what could be wrong? The configure/make log files are attached.
> Regards,
> Tabrez
> <configure.log.gz><make.log.gz>
> From: <petsc-dev-request at mcs.anl.gov>
> Subject: confirm 7c295e8fe09ea4f3c3c0a749f184d1c2a69cdf8a
> Date: August 25, 2019 at 7:55:33 AM CDT
> If you reply to this message, keeping the Subject: header intact,
> Mailman will discard the held message.  Do this if the message is
> spam.  If you reply to this message and include an Approved: header
> with the list password in it, the message will be approved for posting
> to the list.  The Approved: header can also appear in the first line
> of the body of the reply.
