[petsc-dev] Sequential external packages and MPI
    Balay, Satish
    balay at mcs.anl.gov
    Thu Aug 22 07:24:06 CDT 2019
On Thu, 22 Aug 2019, Pierre Jolivet via petsc-dev wrote:
> >> Hello,
> >> PETSc is linking “sequential” libraries with MPI libraries.
> >> $ otool -L libmetis.dylib
> >> 	/usr/local/opt/mpich/lib/libmpi.12.dylib (compatibility version 14.0.0, current version 14.7.0)
> >> $ otool -L libfftw3.dylib
> > this will occur if one uses mpi compilers to build PETSc.
> Why, though?
> If MPICXX_SHOW != “Unavailable”, is it mandatory to force CXX=MPICXX in Metis CMake?
> Wouldn’t it be possible to just extract the compiler binary name and use that as CXX?
Its not easy to get this working universally. [not every mpi compiler wrapper supports show]
However you can get this behavior if you follow Jed's suggestion.
- prebuild mpi [not use -download-mpich or --download-openmpi] - specify required compilers to mpi
- get mpi compiler/library info with 'mpicc -show' etc..
- run petsc configure with
./configure --with-cc= --with-fc= --with-cxx= --with-mpi-include= --with-mpi-lib=
> I understand you don’t want to either overcomplicate things or fix something that is not broken — for you — so I’m just making sure that it would be OK if I patch this like that locally.
> >> Is there anyway to avoid this, by using a “sequential” compiler and/or linker?
> > Yes - you can build these (sequential) packages/petsc with --with-mpi=0 [and without mpi compilers]
> >> I’m asking because we use PETSc libraries to compile both parallel and sequential wrappers.
> >> Our Metis wrapper is marked as a sequential one, but since you are linking libmetis with MPI, this is problematic for some configurations.
> > Not sure what What mean by 'wrappers' here - esp 'Metis wrapper'. Its
> > just a library.
> It’s just another dynamic library compiled on top of libmetis that is then dynamically loaded by a DSL, which may or may not be launched with MPIRUN.
> > If you are using petsc build tools to install these packages for a
> > different use [other than the petsc usage specified by configure] -
> > use different petsc builds as indicated above for different packages -
> > as needed.
> Having to configure + build PETSc with both real and complex numbers is already long enough.
> That would mean a 3rd build, but why not.
> Are there some guarantees that CXX with --with-mpi=0 will be the same as the underlying compiler of MPICXX? (I’m thinking of incompatible libc++ that would make it impossible to link in the same library Metis and the later one compiled PETSc with --with-mpi=1)
Here you would specify compatible compilers to petsc configure. [as indicated above]
Satish
> Thanks,
> Pierre
> > BTW: Current petsc configure/builder builds only parallel fftw. [it does not support building sequential fftw. But I guess this could be added]
> > Satish
