[petsc-dev] IMPORTANT PETSc repository changed from Bucketbit to GitLab
    Balay, Satish
    balay at mcs.anl.gov
    Mon Aug 19 15:47:48 CDT 2019
A note:
The bitbucket repository is saved at https://bitbucket.org/petsc/petsc-pre-gitlab
The git part is now read-only. The other parts [issues, PRs, wiki etc] are perhaps writable - but we should avoid that.
Satish
On Mon, 19 Aug 2019, Smith, Barry F. via petsc-dev wrote:
>    PETSc folks.
>     This announcement is for people who access PETSc from the BitBucket repository or post issues or have other activities with the Bitbucket repository
>    We have changed  the location of the PETSc repository from BitBucket to GitLab. For each copy of the repository you need to do
>    git remote set-url origin git at gitlab.com<mailto:git at gitlab.com>:petsc/petsc.git
>    or
>    git remote set-url origin https://gitlab.com/petsc/petsc.git
>    You will likely also want to set up an account on gitlab and remember to set the ssh key information
>    if you previously had write permission to the petsc repository and cannot write to the new repository please email bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov> with your GitLab
>    username and the email used
>     Please do not make pull requests to the Gitlab site yet; we will be manually processing the PR from the BitBucket site over the next couple of
>     days as we implement the testing.
>     Please be patient, this is all new to use and it may take a few days to get out all the glitches.
>     Thanks for your support
>     Barry
>    The reason for switching to GitLab is that it has a better testing system than BitBucket and Gitlab. We hope that will allow us to test and manage
>    pull requests more rapidly, efficiently and accurately, thus allowing us to improve and add to PETSc more quickly.
