[petsc-dev] [petsc-maint] running CUDA on SUMMIT
Mark Adams
mfadams at lbl.gov
Wed Aug 14 21:23:29 CDT 2019
I am getting this error with single:
22:21 /gpfs/alpine/geo127/scratch/adams$ jsrun -n 1 -a 1 -c 1 -g 1
./ex56_single -cells 2,2,2 -ex56_dm_vec_type cuda -ex56_dm_mat_type
aijcusparse -fp_trap
[0] 81 global equations, 27 vertices
[0]PETSC ERROR: *** unknown floating point error occurred ***
[0]PETSC ERROR: The specific exception can be determined by running in a
debugger. When the
[0]PETSC ERROR: debugger traps the signal, the exception can be found with
fetestexcept(0x3e000000)
[0]PETSC ERROR: where the result is a bitwise OR of the following flags:
[0]PETSC ERROR: FE_INVALID=0x20000000 FE_DIVBYZERO=0x4000000
FE_OVERFLOW=0x10000000 FE_UNDERFLOW=0x8000000 FE_INEXACT=0x2000000
[0]PETSC ERROR: Try option -start_in_debugger
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: --------------------- Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR: INSTEAD the line number of the start of the function
[0]PETSC ERROR: is given.
[0]PETSC ERROR: [0] PetscDefaultFPTrap line 355
/autofs/nccs-svm1_home1/adams/petsc/src/sys/error/fp.c
[0]PETSC ERROR: [0] PetscStrtod line 1964
/autofs/nccs-svm1_home1/adams/petsc/src/sys/objects/options.c
[0]PETSC ERROR: [0] PetscOptionsStringToReal line 2021
[0]PETSC ERROR: [0] PetscOptionsGetReal line 2321
[0]PETSC ERROR: [0] PetscOptionsReal_Private line 1015
/autofs/nccs-svm1_home1/adams/petsc/src/sys/objects/aoptions.c
[0]PETSC ERROR: [0] KSPSetFromOptions line 329
/autofs/nccs-svm1_home1/adams/petsc/src/ksp/ksp/interface/itcl.c
[0]PETSC ERROR: [0] SNESSetFromOptions line 869
/autofs/nccs-svm1_home1/adams/petsc/src/snes/interface/snes.c
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Floating point exception
[0]PETSC ERROR: trapped floating point error
[0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.11.3-1685-gd3eb2e1 GIT
Date: 2019-08-13 06:33:29 -0400
[0]PETSC ERROR: ./ex56_single on a arch-summit-dbg-single-pgi-cuda named
h36n11 by adams Wed Aug 14 22:21:56 2019
[0]PETSC ERROR: Configure options --with-cc=mpicc --with-cxx=mpiCC
--with-fc=mpif90 COPTFLAGS="-g -Mfcon" CXXOPTFLAGS="-g -Mfcon"
FOPTFLAGS="-g -Mfcon" --with-precision=single --with-ssl=0 --with-batch=0
--with-mpiexec="jsrun -g 1" --with-cuda=1 --with-cudac=nvcc
CUDAFLAGS="-ccbin pgc++" --download-metis --download-parmetis
--download-fblaslapack --with-x=0 --with-64-bit-indices=0
--with-debugging=1 PETSC_ARCH=arch-summit-dbg-single-pgi-cuda
[0]PETSC ERROR: #1 User provided function() line 0 in Unknown file
On Wed, Aug 14, 2019 at 9:51 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> Oh, doesn't even have to be that large. We just need to be able to look
> at the flop rates (as a surrogate for run times) and compare with the
> previous runs. So long as the size per process is pretty much the same that
> is good enough.
> Barry
> > On Aug 14, 2019, at 8:45 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > I can run single, I just can't scale up. But I can use like 1500
> processors.
> > On Wed, Aug 14, 2019 at 9:31 PM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> > Oh, are all your integers 8 bytes? Even on one node?
> > Once Karl's new middleware is in place we should see about reducing to
> 4 bytes on the GPU.
> > Barry
> > > On Aug 14, 2019, at 7:44 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > > OK, I'll run single. It a bit perverse to run with 4 byte floats and 8
> byte integers ... I could use 32 bit ints and just not scale out.
> > > On Wed, Aug 14, 2019 at 6:48 PM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> > > Mark,
> > > Oh, I don't even care if it converges, just put in a fixed number
> of iterations. The idea is to just get a baseline of the possible
> improvement.
> > > ECP is literally dropping millions into research on "multi
> precision" computations on GPUs, we need to have some actual numbers for
> the best potential benefit to determine how much we invest in further
> investigating it, or not.
> > > I am not expressing any opinions on the approach, we are just in
> the fact gathering stage.
> > > Barry
> > > > On Aug 14, 2019, at 2:27 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > > > On Wed, Aug 14, 2019 at 2:35 PM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> > > > Mark,
> > > > Would you be able to make one run using single precision? Just
> single everywhere since that is all we support currently?
> > > > Experience in engineering at least is single does not work for FE
> elasticity. I have tried it many years ago and have heard this from others.
> This problem is pretty simple other than using Q2. I suppose I could try
> it, but just be aware the FE people might say that single sucks.
> > > > The results will give us motivation (or anti-motivation) to have
> support for running KSP (or PC (or Mat) in single precision while the
> simulation is double.
> > > > Thanks.
> > > > Barry
> > > > For example if the GPU speed on KSP is a factor of 3 over the double
> on GPUs this is serious motivation.
> > > > > On Aug 14, 2019, at 12:45 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > > > > FYI, Here is some scaling data of GAMG on SUMMIT. Getting about 4x
> GPU speedup with 98K dof/proc (3D Q2 elasticity).
> > > > > This is weak scaling of a solve. There is growth in iteration
> count folded in here. I should put rtol in the title and/or run a fixed
> number of iterations and make it clear in the title.
> > > > > Comments welcome.
> <out_cpu_012288><out_cpu_001536><out_cuda_012288><out_cpu_000024><out_cpu_000192><out_cuda_001536><out_cuda_000192><out_cuda_000024><weak_scaling_cpu.png><weak_scaling_cuda.png>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190814/986d1b34/attachment.html>
