[petsc-dev] Periodic meshes with <3 elements per edge?
Matthew Knepley
knepley at gmail.com
Wed Aug 14 20:33:50 CDT 2019
On Wed, Aug 14, 2019 at 3:18 PM Patrick Sanan <patrick.sanan at gmail.com>
wrote:
> Am Mi., 14. Aug. 2019 um 20:15 Uhr schrieb Jed Brown via petsc-dev <
> petsc-dev at mcs.anl.gov>:
>> Matthew Knepley <knepley at gmail.com> writes:
>> >> > On Tue, Aug 13, 2019 at 7:35 PM Stefano Zampini <
>> >> stefano.zampini at gmail.com>
>> >> > wrote:
>> >> >> On Aug 14, 2019, at 1:19 AM, Jed Brown via petsc-dev <
>> >> >> petsc-dev at mcs.anl.gov> wrote:
>> >> >> [Cc: petsc-dev]
>> >> >> Also, why is our current mode of localized coordinates preferred
>> over
>> >> >> the coordinate DM being non-periodic? Is the intent to preserve
>> that
>> >> >> for every point in a DM, the point is also valid in the coordinate
>> DM?
>> >> >> Yes.
>> >> >> Can there be "gaps" in a chart?
>> >> >> Yes.
>> >> >> I've been digging around in the implementation because there is no
>> >> >> documentation of localized coordinates, but it feels more
>> complicated
>> >> >> than I'd have hoped.
>> >> >> A while ago, “localization” of coordinates was supporting only very
>> >> simple
>> >> >> cases, where periodic points were identified though the ‘maxCell’
>> >> parameter
>> >> >> (used to compute the proper cell coordinates). I think this is the
>> >> reason
>> >> >> why you need at least 3 cells to support periodicity, since the
>> BoxMesh
>> >> >> constructor uses the maxCell trick.
>> >> > This was my original conception since it was the only fully
>> automatic way
>> >> > to apply periodicity on an unstructured mesh that
>> >> > was read from a file or generator.
>> >> I take it this is in reference to this logic.
>> >> PetscErrorCode DMLocalizeCoordinateReal_Internal(DM dm, PetscInt dim,
>> >> const PetscReal anchor[], const PetscReal in[], PetscReal out[])
>> >> PetscInt d;
>> >> PetscFunctionBegin;
>> >> if (!dm->maxCell) {
>> >> for (d = 0; d < dim; ++d) out[d] = in[d];
>> >> } else {
>> >> for (d = 0; d < dim; ++d) {
>> >> if ((dm->bdtype[d] != DM_BOUNDARY_NONE) &&
>> (PetscAbsReal(anchor[d] -
>> >> in[d]) > dm->maxCell[d])) {
>> >> out[d] = anchor[d] > in[d] ? dm->L[d] + in[d] : in[d] -
>> dm->L[d];
>> >> } else {
>> >> out[d] = in[d];
>> >> PetscFunctionReturn(0);
>> >> This implies that the mesh be aligned to coordinates (at least in the
>> >> periodic dimension)
>> > No, it does not. That is the point, that you can have edges crossing the
>> > periodic boundary.
>> I mean that u(x) = u(x+(L,0)) rather than u(x) = u(x+v) where ||v||=L is
>> arbitrary.
>> >> An (unstructured) mesh generator has to support periodicity anyway to
>> >> generate a mesh with that topology.
>> > Or you can fake it.
>> How would you handle a different number/distribution of points on
>> surfaces that are meant to be joined periodically?
I meant mesh something like an annulus and map to the cylinder.
> >> >> The DMPlex code fully support coordinates localized only in those
>> cells
>> >> >> touching the periodic boundary. (I’m not a fan of this, since it
>> >> requires a
>> >> >> lot of ‘if’ ‘else’ switches )
>> >> > I believe that Lisandro wanted this to cut down on redundant storage
>> of
>> >> > coordinates.
>> >> What was the rationale for having these special cells with
>> >> localized/DG-style coordinates versus storing coordinates as a
>> >> non-periodic continuous field?
>> > I do not understand what you mean.
>> >> The local points could be distinct for
>> >> both fields and coordinates, with the global SF de-duplicating the
>> >> periodic points for fields, versus leaving them distinct for
>> >> coordinates.
>> > Oh, no I would never do that.
>> Can you help me understand why that model is bad?
> I'm also interested in the answer to this question, because I am
> considering something similar for DMStag; if DM has a periodic BC, the
> corresponding coordinate DM has a "none" BC, so the boundary points are
> duplicated - this would hopefully make it much easier to locate particles
> in elements.
If you start asking topological questions of the mesh, it looked
complicated to get them all right. For example, if you start expanding the
overlap
over the periodic boundary. Fundamentally, periodicity is a topological
notion. It is not defined by the coordinate chart.
Matt
>> >> (Global coordinates are often not used.) It seems like a
>> >> simpler model to me, and would eliminate a lot of if/else statements,
>> >> but you've been thinking about this more than me.
>> >> >> I think domain_box_size 1 is not possible, we can probably allow
>> >> >> domain_box_size 2.
>> >> > Technically, now a single box is possible with higher order
>> coordinate
>> >> > spaces, but you have to do everything by hand
>> >> > and it completely untested.
>> >> Why would higher order coordinate spaces be needed? I could localize
>> >> coordinates for all cells.
>> > I mean if you wanted a single cell that was periodic, you could do that
>> > with higher order coordinates.
>> But it would also work with linear coordinates, no? (Assume the user
>> localizes their own coordinates.)
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190814/a23739d3/attachment.html>
