[petsc-dev] Periodic meshes with <3 elements per edge?
    Jed Brown
    jed at jedbrown.org
    Wed Aug 14 13:15:17 CDT 2019
Matthew Knepley <knepley at gmail.com> writes:
>> > On Tue, Aug 13, 2019 at 7:35 PM Stefano Zampini <
>> stefano.zampini at gmail.com>
>> > wrote:
>> >> On Aug 14, 2019, at 1:19 AM, Jed Brown via petsc-dev <
>> >> petsc-dev at mcs.anl.gov> wrote:
>> >> [Cc: petsc-dev]
>> >> Also, why is our current mode of localized coordinates preferred over
>> >> the coordinate DM being non-periodic?  Is the intent to preserve that
>> >> for every point in a DM, the point is also valid in the coordinate DM?
>> >> Yes.
>> >> Can there be "gaps" in a chart?
>> >> Yes.
>> >> I've been digging around in the implementation because there is no
>> >> documentation of localized coordinates, but it feels more complicated
>> >> than I'd have hoped.
>> >> A while ago, “localization” of coordinates was supporting only very
>> simple
>> >> cases, where periodic points were identified though the ‘maxCell’
>> parameter
>> >> (used to compute  the proper cell coordinates). I think this is the
>> reason
>> >> why you need at least 3 cells to support periodicity, since the BoxMesh
>> >> constructor uses the maxCell trick.
>> > This was my original conception since it was the only fully automatic way
>> > to apply periodicity on an unstructured mesh that
>> > was read from a file or generator.
>> I take it this is in reference to this logic.
>> PetscErrorCode DMLocalizeCoordinateReal_Internal(DM dm, PetscInt dim,
>> const PetscReal anchor[], const PetscReal in[], PetscReal out[])
>>   PetscInt d;
>>   PetscFunctionBegin;
>>   if (!dm->maxCell) {
>>     for (d = 0; d < dim; ++d) out[d] = in[d];
>>   } else {
>>     for (d = 0; d < dim; ++d) {
>>       if ((dm->bdtype[d] != DM_BOUNDARY_NONE) && (PetscAbsReal(anchor[d] -
>> in[d]) > dm->maxCell[d])) {
>>         out[d] = anchor[d] > in[d] ? dm->L[d] + in[d] : in[d] - dm->L[d];
>>       } else {
>>         out[d] = in[d];
>>   PetscFunctionReturn(0);
>> This implies that the mesh be aligned to coordinates (at least in the
>> periodic dimension)
> No, it does not. That is the point, that you can have edges crossing the
> periodic boundary.
I mean that u(x) = u(x+(L,0)) rather than u(x) = u(x+v) where ||v||=L is
arbitrary.
>> An (unstructured) mesh generator has to support periodicity anyway to
>> generate a mesh with that topology.
> Or you can fake it.
How would you handle a different number/distribution of points on
surfaces that are meant to be joined periodically?
>> >> The DMPlex code fully support coordinates localized only in those cells
>> >> touching the periodic boundary. (I’m not a fan of this, since it
>> requires a
>> >> lot of ‘if’ ‘else’ switches )
>> > I believe that Lisandro wanted this to cut down on redundant storage of
>> > coordinates.
>> What was the rationale for having these special cells with
>> localized/DG-style coordinates versus storing coordinates as a
>> non-periodic continuous field?
> I do not understand what you mean.
>> The local points could be distinct for
>> both fields and coordinates, with the global SF de-duplicating the
>> periodic points for fields, versus leaving them distinct for
>> coordinates.
> Oh, no I would never do that.
Can you help me understand why that model is bad?
>> (Global coordinates are often not used.)  It seems like a
>> simpler model to me, and would eliminate a lot of if/else statements,
>> but you've been thinking about this more than me.
>> >> I think domain_box_size 1 is not possible, we can probably allow
>> >> domain_box_size 2.
>> > Technically, now a single box is possible with higher order coordinate
>> > spaces, but you have to do everything by hand
>> > and it completely untested.
>> Why would higher order coordinate spaces be needed?  I could localize
>> coordinates for all cells.
> I mean if you wanted a single cell that was periodic, you could do that
> with higher order coordinates.
But it would also work with linear coordinates, no?  (Assume the user
localizes their own coordinates.)
