[petsc-dev] running test
Balay, Satish
balay at mcs.anl.gov
Tue Aug 13 11:15:59 CDT 2019
On Tue, 13 Aug 2019, Mark Adams via petsc-dev wrote:
> I want to test a test as it will be executed. Can someone please tell me
> how do I run a "cuda" test SNES ex56 exactly?
> This is the test in ex56.c
> test:
> suffix: cuda
> nsize: 2
> requires: cuda
> args: -cel ....
mpiexec -n 2 ./ex56 -cel ....
You can check the scripts that are generated - that do the run and diff..
[PETSC_ARCH/tests/snes/examples/tutorials/runex56_cuda.sh]
Satish
> Thanks,
> Mark
