[petsc-dev] Is master broken?
    Mark Adams
    mfadams at lbl.gov
    Mon Aug 12 09:32:58 CDT 2019
>> several issues:
>> https://bitbucket.org/petsc/petsc/pull-requests/1954/cuda-fixes-to-pinning-onto-cpu/diff
> These links are dead.
I found one issue with not protecting the pinnedtocpu member variable in
Mat and Vec. Will fix asap.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190812/5771f1ae/attachment.html>
