[petsc-dev] Redistribution of a DMPlex onto a new communicator
    Lawrence Mitchell
    wence at gmx.li
    Wed Aug  7 10:31:55 CDT 2019
On Wed, 7 Aug 2019 at 13:52, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Aug 7, 2019 at 7:13 AM Lawrence Mitchell via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
>> Dear petsc-dev,
>> I would like to run with a geometric multigrid hierarchy built out of DMPlex objects. On the coarse grids, I would like to reduce the size of the communicator being used. Since I build the hierarchy by regularly refining the coarse grid problem, this means I need a way of redistributing a DMPlex object from commA to commB.
>> (I note that DMRefine has signature DMRefine(oldDM, newcomm, newDM), but as far as I can tell no concrete implementation of DMRefine has ever taken any notice of newcomm, and the newDM always ends up on the same communicator as the oldDM).
>> OK, so I think what I want to use is DMPlexDistribute. This does many-to-many redistribution of DMPlex objects, but has a rather constrained interface:
>> DMPlexDistribute(oldDM, overlap, *migrationSF, *newDM)
>> It works by taking the oldDM, assuming that the communicator of that thing defines the number of partitions I want, partitioning the mesh dual graph, and migrating onto a newDM, with the same number of processes as the oldDM.
>> So what are my options if I want to distribute from oldDM onto newDM where the communicators of the oldDM and the putative target newDM /don't/ match?
>> Given my use case above, right now I can assume that MPI_Group_translate_ranks(oldcomm, newcomm) will work (although I can think of future use cases where it doesn't).
>> In an ideal world, I think the interface for DMPlexDistribute should be something like:
>> DMPlexDistribute(oldDM, overlap, newComm, *migrationSF, *newDM)
>> where oldDM->comm and newComm are possibly disjoint sets of ranks, and the call is collective over the union of the groups of the two communicators.
>> This would work by then asking the partitioner to construct a partition based on the size of newComm (rather than oldDM->comm) and doing all of the migration.
>> I started to look at this, and swiftly threw my hands in the air, because the implicit assumption of the communicators matching is everywhere.
>> So my stopgap solution would be (given that I know oldDM->comm \subset newComm) is to take my oldDM and move it onto newComm before calling the existing DMPlexDistribute.
>> Does this sound like a reasonable approach? Effectively I need to create "empty" DM objects on all of the participating ranks in newComm that are not in oldComm: what information do they need to contain to align with oldDM?
>> Does anyone else just have code for doing this lying around? Am I completely barking up the wrong tree?
> That is how you do it. We are solidifying this pattern, as you can see from Junchao's new example for pushing a Vec onto a subcomm.
OK, so I think I am getting there. Presently I am abusing
DMPlexCreateFromDAG to migrate a DM on oldComm onto newComm, but this
is very fragile. I attach what I have right now. You have to run it
with PTSCOTCH, because parmetis refuses to partition graphs with no
vertices on a process.: again, this would be avoided if the
partitioning was done on a source communicator with a number of
partitions given by a target communicator, anyway.
This example builds a simple DMPlex on a subcommunicator (built with
processes from COMM_WORLD where rank % 3 == 0), and then refines it,
and redistributes it onto COMM_WORLD.
Running with:
$ mpiexec -n 4 ./dmplex-redist -input_dm_view -refined_dm_view
-copied_dm_view -redistributed_dm_view
Builds a box mesh on 1 rank, redistributes it onto 2, refines that DM,
then expands it to live on 4 ranks, and subsequently redistributes
that.
DM Object: 2 MPI processes
  type: plex
DM_0x84000007_0 in 3 dimensions:
  0-cells: 27 0
  1-cells: 54 0
  2-cells: 36 0
  3-cells: 8 0
Labels:
  depth: 4 strata with value/size (0 (27), 1 (54), 2 (36), 3 (8))
  Face Sets: 6 strata with value/size (6 (4), 5 (4), 3 (4), 4 (4), 1 (4), 2 (4))
  marker: 1 strata with value/size (1 (72))
  type: plex
DM_0x84000007_1 in 3 dimensions:
  0-cells: 75 75
  1-cells: 170 170
  2-cells: 128 128
  3-cells: 32 32
Labels:
  marker: 1 strata with value/size (1 (192))
  Face Sets: 5 strata with value/size (1 (36), 3 (18), 4 (18), 5 (18), 6 (18))
  depth: 4 strata with value/size (0 (75), 1 (170), 2 (128), 3 (32))
DM Object: 4 MPI processes
  type: plex
DM_0xc4000003_0 in 3 dimensions:
  0-cells: 75 0 0 75
  1-cells: 170 0 0 170
  2-cells: 128 0 0 128
  3-cells: 32 0 0 32
Labels:
Field PetscContainer_0xc4000003_1:
  adjacency FEM
DM Object: Parallel Mesh 4 MPI processes
  type: plex
Parallel Mesh in 3 dimensions:
  0-cells: 45 45 45 45
  1-cells: 96 96 96 96
  2-cells: 68 68 68 68
  3-cells: 16 16 16 16
Labels:
  depth: 4 strata with value/size (0 (45), 1 (96), 2 (68), 3 (16))
Field PetscContainer_0xc4000003_2:
  adjacency FEM
I would ideally like some help in figuring out a better way of
"expanding" the DM onto the new communicator (rather than using
DMPlexCreateFromDAG as I do now).
I think one wants to think about the interface for these
redistribution functions in general. It seems that they want to
broadly match MPI_Intercomm_create. So something like:
DMPlexDistribute(oldDM, peerCommunicator, newCommunicator, overlap,
This is collective over peerCommunicator and returns a newDM on
newCommunicator, and a migrationSF on peerCommunicator.
Note that I do not think it is safe to assume that PETSC_COMM_WORLD is
always suitable as peerCommunicator.
> I think the right way to do this would be to implement the hooks in PCTELESCOPE for DMPlex. Dave and I have talked about this and
> it should be exactly the same work as you propose above, but it would allow you to use the command line, do this recursively, interact nicely
> with the solvers, etc. I can help.
The telescope side of things now exists (c.f. 8d9f7141f511) to some
degree. But to do that, one needs the redistribution.
Cheers,
Lawrence
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190807/31b21630/attachment-0001.bin>
