[petsc-dev] Is master broken?
Balay, Satish
balay at mcs.anl.gov
Fri Aug 2 22:21:32 CDT 2019
I've attempted to rebase this branch over latest master - and pushed
my changes to branch mark/gamg-fix-viennacl-rebased-v2
You might want to check each of your commits in this branch to see if
they are ok. I had to add one extra commit - to make it match 'merge
of mark/gamg-fix-viennacl-rebased and master'.
This branch has 21 commits. I think its best if you can collapse them
into reasonable chunks of changes. [presumably a single commit for all
the changes is not the correct thing here. But the current set of 21
commits are all over the place]
If you are able to migrate to this branch - its best to delete the old
one [i.e origin/mark/gamg-fix-viennacl-rebased]
Satish
On Fri, 2 Aug 2019, Mark Adams via petsc-dev wrote:
> I have been cherry-picking, etc, branch mark/gamg-fix-viennacl-rebased and
> it is very messed up. Can someone please update this branch when all the
> fixes are settled down? eg, I am seeing dozens of modified files that I
> don't know anything about and I certainly don't want to put in a PR for
> them.
> I also seem to lose my pinToCPU method for cuda matrices. I don't
> understand how that conflicted with anyone else but it did.
> Thanks,
> Mark
