[petsc-dev] [petsc-checkbuilds] PETSc blame digest (next) 2019-04-26
Karl Rupp
rupp at iue.tuwien.ac.at
Fri Apr 26 08:37:38 CDT 2019
I fixed this warning after merge.
Best regards,
Karli
On 4/26/19 2:28 PM, PETSc checkBuilds via petsc-checkbuilds wrote:
> Dear PETSc developer,
> This email contains listings of contributions attributed to you by
> `git blame` that caused compiler errors or warnings in PETSc automated
> testing. Follow the links to see the full log files. Please attempt to fix
> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are unable
> to resolve the issues.
> Thanks,
> The PETSc development team
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/beae5ec
> rm malloc of iidx array of size nrhs*M for sparse rhs matrix.
> src/mat/impls/aij/mpi/mumps/mumps.c:1068
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/04/26/build_next_arch-linux-pkgs-gcov_cg.log]
> /sandbox/petsc/petsc.next-2/src/mat/impls/aij/mpi/mumps/mumps.c:1068:54: warning: 'iidx' may be used uninitialized in this function [-Wmaybe-uninitialized]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/04/26/build_next_arch-freebsd-cxx-pkgs-opt_wii.log]
> /usr/home/balay/petsc.next-2/src/mat/impls/aij/mpi/mumps/mumps.c:1068:54: warning: 'iidx' may be used uninitialized in this function [-Wmaybe-uninitialized]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/04/26/build_next_arch-linux-pkgs-valgrind_es.log]
> /sandbox/petsc/petsc.next/src/mat/impls/aij/mpi/mumps/mumps.c:1068:54: warning: 'iidx' may be used uninitialized in this function [-Wmaybe-uninitialized]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/04/26/build_next_arch-freebsd-cxx-cmplx-pkgs-dbg_wii.log]
> /usr/home/balay/petsc.next/src/mat/impls/aij/mpi/mumps/mumps.c:1068:54: warning: 'iidx' may be used uninitialized in this function [-Wmaybe-uninitialized]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/04/26/build_next_arch-c-exodus-dbg-builder_frog.log]
> /sandbox/petsc/petsc.next-3/src/mat/impls/aij/mpi/mumps/mumps.c:1068:54: warning: 'iidx' may be used uninitialized in this function [-Wmaybe-uninitialized]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/04/26/build_next_arch-linux-pkgs-cxx-mlib_el6.log]
> /home/sandbox/petsc/petsc.next-3/src/mat/impls/aij/mpi/mumps/mumps.c:1068:54: warning: 'iidx' may be used uninitialized in this function [-Wmaybe-uninitialized]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/04/26/build_next_arch-freebsd-pkgs-opt_wii.log]
> /usr/home/balay/petsc.next-3/src/mat/impls/aij/mpi/mumps/mumps.c:1068:54: warning: 'iidx' may be used uninitialized in this function [-Wmaybe-uninitialized]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/04/26/build_next_arch-linux-pkgs-opt_crank.log]
> To opt-out from receiving these messages - send a request to petsc-dev at mcs.anl.gov.
