[petsc-dev] MatComputeExplicitOperator
    Stefano Zampini
    stefano.zampini at gmail.com
    Sat Apr 20 13:30:58 CDT 2019
Using preallocator will require looping twice for the computation of the
entries, and this may be very expensive.
In my case, every MatMult requires one forward and one backward TS solve.
We can either use AIJ or DENSE format, but I think this should be the same
for the sequential or parallel runs, not as it is now.
Il giorno sab 20 apr 2019 alle ore 14:20 Matthew Knepley <knepley at gmail.com>
ha scritto:
> On Fri, Apr 19, 2019 at 5:58 PM Smith, Barry F. via petsc-dev <
> petsc-dev at mcs.anl.gov> wrote:
>>    I think MPIAIJ was selected because it provided the most parallel
>> functionality compared to MPIDENSE for which more operations were not
>> written.
>>    This may not be relevant any more.
>>     Definitely the code needs to be fixed. Fixing MatConvert_Shell(); it
>> should just assume
>> the matrices are dense and preallocate for them.
> We should restore preallocation. It should be easy to do with Preallocator.
>   Matt
>>    Barry
>> > On Apr 19, 2019, at 3:07 PM, Stefano Zampini via petsc-dev <
>> > What is the rationale behind MatComputeExplicitOperator returning
>> SEQDENSE in sequential and MPIAIJ in parallel?
>> > Also, before commit
>> https://bitbucket.org/petsc/petsc/commits/b3d09e869df0e6ebcb615ca876706bfed4fcf1cd
>> full preallocation of the MPIAIJ matrix was happening. Now, if we have a
>> very dense operator that we want to sample just for testing purposes
>> (inspecting entries, etc..) we have to pay the price of reallocating over
>> and over.
>> > What is the proper fix? 1) Use MPIDENSE? 2) Restore full preallocation
>> for MPIAIJ? 3) Have MatComputeExplicitOperator to accept more arguments ?
>> > I'm in favor of 1
>> > Stefano
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190420/d62667af/attachment.html>
