[petsc-dev] Something changed with SBAIJ on april 17?
Éric Chamberland
Eric.Chamberland at giref.ulaval.ca
Fri Apr 19 07:25:18 CDT 2019
Looks like something pushed on master change or broke some sbaij
usages. I have two kind off errors with MatCopy:
1) MatCopy error saying: No support for this operation for this object type
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: No support for this operation for this object type
[0]PETSC ERROR: MatGetRow is not supported for SBAIJ matrix format. Getting the upper triangular part of row, run with -mat_getrow_uppertriangular, call MatSetOption(mat,MAT_GETROW_UPPERTRIANGULAR,PETSC_TRUE) or MatGetRowUpperTriangular()
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.11.1-277-g63b3610 GIT Date: 2019-04-18 08:33:56 -0500
[0]PETSC ERROR: /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/BIB/bin/Test.deliMEFPP.dev on a named compile by Unknown Fri Apr 19 03:19:09 2019
[0]PETSC ERROR: Configure options --prefix=/opt/petsc-master_debug --with-mpi-compilers=1 --with-mpi-dir=/opt/openmpi-1.10.2 --with-cxx-dialect=C++11 --with-make-np=12 --with-shared-libraries=1 --with-debugging=yes --with-memalign=64 --with-visibility=0 --with-64-bit-indices=0 --download-ml=yes --download-mumps=yes --download-superlu=yes --download-superlu_dist=yes --download-parmetis=yes --download-ptscotch=yes --download-metis=yes --download-suitesparse=yes --download-hypre=yes --with-blaslapack-dir=/opt/intel/composer_xe_2015.2.164/mkl/lib/intel64 --with-mkl_pardiso-dir=/opt/intel/composer_xe_2015.2.164/mkl --with-mkl_cpardiso-dir=/opt/intel/composer_xe_2015.2.164/mkl --with-scalapack=1 --with-scalapack-include=/opt/intel/composer_xe_2015.2.164/mkl/include --with-scalapack-lib="-L/opt/intel/composer_xe_2015.2.164/mkl/lib/intel64 -lmkl_scalapack_lp64 -lmkl_blacs_openmpi_lp64"
[0]PETSC ERROR: #1 MatGetRow_SeqSBAIJ() line 281 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/impls/sbaij/seq/sbaij.c
[0]PETSC ERROR: #2 MatGetRow() line 574 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/interface/matrix.c
[0]PETSC ERROR: #3 MatAXPY_Basic_Preallocate() line 138 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/utils/axpy.c
[0]PETSC ERROR: #4 MatAXPY() line 95 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/utils/axpy.c
[0]PETSC ERROR: #5 MatAYPX() line 384 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/utils/axpy.c
[0]PETSC ERROR: #6 MatCopy_Basic() line 4056 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/interface/matrix.c
[0]PETSC ERROR: #7 MatCopy_SeqAIJ() line 2844 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/impls/aij/seq/aij.c
[0]PETSC ERROR: #8 MatCopy() line 4110 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/interface/matrix.c
2) MatCopy error saying:
Argument out of range: New nonzero at (6,7) caused a malloc
[0]PETSC ERROR: Argument out of range
[0]PETSC ERROR: New nonzero at (6,7) caused a malloc
Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to turn off this check
[0]PETSC ERROR: /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/BIB/bin/Test.BIBProblemeGD.dev on a named compile by Unknown Fri Apr 19 03:22:25 2019
[0]PETSC ERROR: #1 MatSetValues_SeqSBAIJ() line 990 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/impls/sbaij/seq/sbaij.c
[0]PETSC ERROR: #2 MatSetValues() line 1404 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/interface/matrix.c
[0]PETSC ERROR: #3 MatAXPY_BasicWithPreallocation() line 209 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/utils/axpy.c
[0]PETSC ERROR: #4 MatAXPY() line 96 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/utils/axpy.c
Here are my installation logs as of april 18, at 02h00:
http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_configure.log
http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_make.log
http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_default.log
http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_RDict.log
http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_CMakeLists.txt
http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_make_test.log
http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_make_streams.log
Eric
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190419/33554aa4/attachment.html>
