[petsc-dev] New implementation of PtAP based on all-at-once algorithm
Mark Adams
mfadams at lbl.gov
Mon Apr 15 14:42:14 CDT 2019
>> I wonder if the their symbolic setup is getting called every time. You do
>> 50 solves it looks like and that should be enough to amortize a one time
>> setup cost.
> Hypre does not have concept called symbolic. They do everything from
> scratch, and won't reuse any data.
Really, Hypre does not cache the maps and non-zero structure, etc, that is
generated in RAP?
I suspect that that is contributing to Hypres poor performance, but it is
not the whole story as you are only doing 5 solves.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190415/495ac0ac/attachment.html>
