[petsc-dev] New implementation of PtAP based on all-at-once algorithm
Smith, Barry F.
bsmith at mcs.anl.gov
Thu Apr 11 22:42:49 CDT 2019
> On Apr 11, 2019, at 9:07 PM, Mark Adams via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> Interesting, nice work.
> It would be interesting to get the flop counters working.
> This looks like GMG, I assume 3D.
> The degree of parallelism is not very realistic. You should probably run a 10x smaller problem, at least, or use 10x more processes.
Why do you say that? He's got his machine with a certain amount of physical memory per node, are you saying he should ignore/not use 90% of that physical memory for his simulation? He should buy a machine 10x bigger just because it means having less degrees of freedom per node (whose footing the bill for this purchase?). At INL they run simulations for a purpose, not just for scalability studies and there are no dang GPUs or barely used over-sized monstrocities sitting around to brag about twice a year at SC.
Barry
> I guess it does not matter. This basically like a one node run because the subdomains are so large.
> And are you sure the numerics are the same with and without hypre? Hypre is 15x slower. Any ideas what is going on?
> It might be interesting to scale this test down to a node to see if this is from communication.
> Again, nice work,
> Mark
> On Thu, Apr 11, 2019 at 7:08 PM Fande Kong <fdkong.jd at gmail.com> wrote:
> Hi Developers,
> I just want to share a good news. It is known PETSc-ptap-scalable is taking too much memory for some applications because it needs to build intermediate data structures. According to Mark's suggestions, I implemented the all-at-once algorithm that does not cache any intermediate data.
> I did some comparison, the new implementation is actually scalable in terms of the memory usage and the compute time even though it is still slower than "ptap-scalable". There are some memory profiling results (see the attachments). The new all-at-once implementation use the similar amount of memory as hypre, but it way faster than hypre.
> For example, for a problem with 14,893,346,880 unknowns using 10,000 processor cores, There are timing results:
> Hypre algorithm:
> MatPtAP 50 1.0 3.5353e+03 1.0 0.00e+00 0.0 1.9e+07 3.3e+04 6.0e+02 33 0 1 0 17 33 0 1 0 17 0
> MatPtAPSymbolic 50 1.0 2.3969e-0213.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> MatPtAPNumeric 50 1.0 3.5353e+03 1.0 0.00e+00 0.0 1.9e+07 3.3e+04 6.0e+02 33 0 1 0 17 33 0 1 0 17 0
> PETSc scalable PtAP:
> MatPtAP 50 1.0 1.1453e+02 1.0 2.07e+09 3.8 6.6e+07 2.0e+05 7.5e+02 2 1 4 6 20 2 1 4 6 20 129418
> MatPtAPSymbolic 50 1.0 5.1562e+01 1.0 0.00e+00 0.0 4.1e+07 1.4e+05 3.5e+02 1 0 3 3 9 1 0 3 3 9 0
> MatPtAPNumeric 50 1.0 6.3072e+01 1.0 2.07e+09 3.8 2.4e+07 3.1e+05 4.0e+02 1 1 2 4 11 1 1 2 4 11 235011
> New implementation of the all-at-once algorithm:
> MatPtAP 50 1.0 2.2153e+02 1.0 0.00e+00 0.0 1.0e+08 1.4e+05 6.0e+02 4 0 7 7 17 4 0 7 7 17 0
> MatPtAPSymbolic 50 1.0 1.1055e+02 1.0 0.00e+00 0.0 7.9e+07 1.2e+05 2.0e+02 2 0 5 4 6 2 0 5 4 6 0
> MatPtAPNumeric 50 1.0 1.1102e+02 1.0 0.00e+00 0.0 2.6e+07 2.0e+05 4.0e+02 2 0 2 3 11 2 0 2 3 11 0
> You can see here the all-at-once is a bit slower than ptap-scalable, but it uses only much less memory.
> Fande
